Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 35
  1. #21
    Member
    Join Date
    Aug 2012
    Posts
    30
    orlando fl
    scag turf tiger 61", gx95, sold f525
    Default Re: Trailering a John Deere sub compact 1026 what size ratchet straps do I need???
    I will say thank you for asking, and I (also) would suggest you find someone (who knows what they are doing) to show you. The one thing no one has talked about is where the other end of the tie down goes. I have seen people hook several heavy duty tie downs and chains to weak/wimpy 1/4 or 5/16" D rings held down by two small non-graded bolts. Basically it will not matter how strong of a tie down you use, if the tie down point fails!
  2. #22
    Platinum Member Code54's Avatar
    Join Date
    Aug 2005
    Posts
    950
    Putnam Co. West Virginia
    Kubota MX5100 (50 Hp, 42.5 pto) 1968 Cub, B7200 HST
    Excellent point! I only use chains hooked to my trailer frame for that exact reason.
    Quote Originally Posted by disney View Post
    1985 B7200 HST
    1968 IH Cub Lowboy (being rebuilt currently)
  3. #23
    Gold Member
    Join Date
    Nov 2012
    Posts
    449
    mansfield,Il
    john deere
    Yes you were smart enough to ask and I should have helped instead of being critical . I was out of line and I apologize .
  4. #24
    Silver Member denverdave66's Avatar
    Join Date
    May 2012
    Posts
    130
    Missouri
    2012 John Deere 1016, FEL, 60"MMM
    Apology accepted Kevin 37b. This tractor stuff is all new to me. I am just a homeowner with 11 acres and I bought a JOHN deere 1026 to mow, brush hog, blade my drive and whatever else I need to do. I have found since I bought it I am using it to help me do lots of projects. When I bought it from the dealer I told him I didn't know a thing about tractors after a bunch of phone calls and a few trips to my house I bet he believes me now! I also bought a new 16' tandem axle Doolittle utility trailer with brakes on both axles. I am trying to figure out the safest way to haul my John Deere. My Dad passed away years ago I am sure if he was around he could help me with lots of these problems but since I don't know I come here and everyone has been so nice to help me with things. I snapped off my sheer bolt I hope that is the correct lingo the 1st time out brushogging but it was an easy fix after someone explained to me how to fix it. I am sure most everyone knows how but I didn't.
    2012 John Deere 1026, 60"MMM, FEL, LandPride box scrapper, 52", LandPride RCR1248 rotary cutter,Landpride RB1560, Landpride quick hitch, RachetRake, Trac Vac 880, Sthil FS90 trimmer/brushcutter, Stihl MS310 chainsaw, Stihl BR600 Magnum Backpack blower, Stihl 180c chainsaw
  5. #25
    Silver Member the old grind's Avatar
    Join Date
    Jul 2012
    Posts
    142
    Mid-Michigan
    J-D 1520(sold), Ford 1520-HST(sold), Terramite T5C, NH T1520 HST, NEW (traded 2 for 1)
    In a discussion forum perhaps opinions don't need apologies as often an they're offered. Many of us are here to learn more than to advise, & skin tends to thicken as personalities are recognized and information is gleaned from consensus. Beyond sixty I've come to appreciate good advice from those half my age. I've learned a lot by over-generalizing my own angle and having the ideas/experiences clarified by those with greater knowledge. Along the way I've also learned to take separate bites of foot and crow.
    OT: A guy once asked what I though of his 'hauling' trailer. My unprintable assessment of his anchor points was meant to imply that he bought a pig in a poke. Yeah, I was pretty embarassed when he said he'd added them himself. I regret how I said it, but surely not what I meant. He had robust 3" d-rings securely anchored by ....... lagging them into his deck boards.... Haven't heard a dumb question asked yet, and IMO innocence is forgiveable... This whole topic deserves at least as much comment as it's generating. Put it out there!
  6. #26
    Join Date
    Jan 2012
    Posts
    219
    Brookshire TEXAS
    LS R4047
    I've been hauling oversize loads for 28 years in the trucking industry. I am not impressed with some of the tractor manufactures not incorporating tie down points on their machines. with that said, you need to tie to the frame of your machine diagonally out to the trailer, be it with chains and binders or straps ( KEEP BOTH OFF THE TIRES) and definitely keep the straps off any sharp edges.I personally dont like cutting the straps, because it limits their usefulness,but instead use the loose ends under the strap as protectors.Any attachment ( FEL or on the 3pt ) needs a separate tie down.
    Basically , if GOD reached down and picked up your trailer and turned it upside down, your load should stay in place.
    Good luck and be safe!
    P.S.. I was told when I was taught to drive truck on the farm" after you have an accident, it's too late to put another chain on"
    2012 LS R4047 , FEL , Backhoe, kingkutter finish mower,68 " rachet rake, Titan skidsteer 72" root Grapple, JD 145,JD166 ........Dodge 3500 cummins, Kenworth w900l Cat powered ...
  7. #27
    Elite Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    4,735
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Between me and my B.I.L. we have had 5 tractors (Yanmar, JD, NH, LS and Kubota) and the only one to have a transport tie down is the Kubota B26. I suppose that may be because it is considered an industrial model and as such would be subjected to lots of hauling. The rest, have to chain over the axles or rear drawbar attachment or some other point as best one can find that wont damage the tractor. A word of advice on chaining or strapping over the front axles, make sure you don't bind any of the steering components. After you put the chains in place, before binding them down, take a close look to make sure that when they are tightened it wont be against any bendable or easily breakable part on the tractor.
    Best advice given was look up your DOT regs. They are pretty clear and make sure any device, chain, strap etc is plainly marked with the grade on the chain and WLL on straps and binders. As for chain, if it isn't marked, it is assumed to be lowest grade made -GR40. I use Gr. 70 chain with ratchet binders for the tractor and then straps for the FEL and any other attachment. All components are rated as high or higher than 1/2 of the load weight.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
  8. #28
    Gold Member
    Join Date
    Sep 2011
    Posts
    309
    Corpus Christi. Tx
    Case 485
    Quote Originally Posted by denverdave66 View Post
    Check out this video, lots of good information in it.
    Load Securement Safety - YouTube
  9. #29
    Gold Member
    Join Date
    Nov 2012
    Posts
    449
    mansfield,Il
    john deere
    Definitely use Grade 70 chains on 4 corners of tractor and run the other end through stake pockets on trailer . If this trailer has a rail around it ,run the chains under it never over . I prefer ratchet binders , easier to use . When you load up , walk around and check everything twice . Straps are fine for any implements , watch the sharp edges . Hope this helps .
  10. #30
    Silver Member El Wood's Avatar
    Join Date
    Apr 2012
    Posts
    208
    Michigan
    JD 3320
    Default
    I want to haul my John deere 1026, I may have my loader and a rear blade on when I haul it. What size ratchet straps do I need? Break strength? I really hate ratchet straps I always have so much problems with them, I have seen those retractable ratchet straps that you push a button to release then tension on them. I might look into getting some of them. Any thoughts?
    I have a JD 3320 and use Quick Loader retractable straps. They work great and I would recommend them to anyone. I hate the traditional ones! I got them at Northern tool. They're rated at 10,000 break strength. This is how I set it up and I think this would work for you...
    Trailering a John Deere sub compact 1026 what size ratchet straps do I need???-image-2458013380.jpg
    Put an axle strap on each side of your front axle and secure to trailer. Put that D ring on your drawbar and then secure each strap to you trailer. Your good to go!
Similar Threads
  1. Rear Blade What size rear blade for my John Deere 1026?
    By denverdave66 in forum Attachments
    Last Post: 02-21-2013, 05:39 PM
  2. What are the best ratchet straps?
    By newbury in forum Related Topics
    Last Post: 10-29-2012, 09:28 AM
  3. John Deere 1026
    By denverdave66 in forum John Deere Owning/Operating
    Last Post: 05-28-2012, 05:41 PM
  4. Chains Ratchet straps or chains?
    By iplumb in forum Kubota Owning/Operating
    Last Post: 05-19-2009, 04:03 PM
  5. Ratchet Straps
    By Philip_L in forum Trailers & Transportation
    Last Post: 11-15-2006, 05:58 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
