Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Veteran Member yelbike's Avatar
    Join Date
    Nov 2011
    Posts
    1,091
    Near Winnipeg, Mb, Canada
    John Deere 2305, 2320,Z465
    Default Tmie for a new battery...or is it?
    I need a new battery in my 2007 truck. Its died a few times in the shop when the tint guys were doing the glass and again when they replaced the roof skin, they kept using. Now it has died twice on me at home. Both times was when I used the factory remote start, it doesn't start than the radio and lights stay on killing the battery. It's fine the rest of the time. So here's my question. I've learnt a little on here about desulfation. Is my battery beyond repair or is it a prime candidate? Is the process like preventative maintaince or is it reactionary repair?
    Thanks for all and any help and suggestions.
    I use this truck as a service truck so it needs to be reliable.
    Carefull what you aim for, Aim for nothing and you will achieve it with amazing accuracy.
  2. #2
    Super Member murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    6,467
    Ohio
    Kioti DK 40-Massey ferguson 135-Simplicity Conquest
    Default Re: Tmie for a new battery...or is it?
    That bottom line of yours says it all, New battery time.
    Murph ------------ Sent from my HP laptop
    Nothing runs like a Deere when being chased by a Kioti
  3. #3
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    12,484
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default
    Figure most 2007 stuff is built in 2006. It owes you nothing and life is too short. Don't be cheap, get a new battery.....lol
    Chris
  4. #4
    Elite Member
    Join Date
    Apr 2004
    Posts
    4,773
    Bay Area-Ca and Olympia WA
    Cat D3, Deere 110 TLB, Kubota BX23, Craftsman Mower
    Batteries are funny... every once in awhile one will surprise me.
    Mom's 2001 Toyota Corolla that she bought new still has the OEM battery 12 years and 65,000 miles later.
    No matter what I do... 7 years is the longest I could get a battery to last in my 85 Truck.
  5. #5
    Join Date
    Nov 2011
    Posts
    6,467
    Ohio
    Hardest for me to keep is motorcycle batterys
  6. #6
    Join Date
    Mar 2010
    Posts
    750
    Maine
    i'm no battery expert, but i think sulfation generally happens to batteries that are left unused for long periods of time. it sounds like this isn't the case with yours. i've seen some pictures of home-brew units to fix this, but it looks like they take a lot of time to do the trick - likely a lot longer than you can go without the vehicle. i'd say buy a new one for now. maybe take a chance and keep the core and build / buy a desulfator to see if it works.
    around here when batteries go for long periods without maintenance or use they often end up freezing in the winter, and then the resulting fluid expansion puts the plates in contact with each other, rendering the battery useless. i've never had the interest to see whether a desulfator works yet myself, though it might be a fun project to try sometime.
  7. #7
    Bronze Member cockeyedMFer's Avatar
    Join Date
    Jul 2011
    Posts
    87
    1959 MF 35 deluxe, gas
    We're trying one of these at work for cars that are in storage for extended periods of time. Unfortunately it will be years before we find out if it actually extends battery life
    6 years has been our maximum lifespan for a battery - that was my wife's 2006 Hyundai daily driver. And when it was replaced it still had some life left, but little reserve capacity so I knew if she left the interior light on at work one more time she'd be stranded so it was replaced.
  8. #8
    Join Date
    Jul 2011
    Posts
    87
    Click image for larger version.
    BatteryMINDer Charger/Maintainer/Desulfater 12V, Model# 2012 | Battery Chargers| Northern Tool + Equipment
    6 years has been our maximum lifespan for a battery - that was my wife's 2006 Hyundai daily driver. Its a simple little car that doesn't put much load on a battery.
  9. #9
    Elite Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    4,735
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    My 2007 Chevy Z71 is still going on original battery even though I completely killed it a month or so ago when I left my trailer hooked up and parked for about a week. I guess the brakes killed it. Anyway, jumped it off and it charged back up. Last winter I noticed that it seemed to be getting weak at starting and expected it to go out but it is still kicking. Might go another year if I don't fully discharge it again. So far this is the longest any battery has lasted me. Most expire after 4 years.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
  10. #10
    Platinum Member crashz's Avatar
    Join Date
    May 2005
    Posts
    944
    Eastern MA & Upstate NY
    John Deere 770, Bobcat 753
    Default
    I typically replace them at 5 years regardless. The battery is the most abused item in my truck. I don't want to take a chance in my wife's car. So the DDs get new batteries. If the batteries are still good, I put them on a trickle charge and use them on our smaller equipment. My charger has the de- sulfurizing feature, but it won't revive dead batteries.
    On everything else,I replace when they get troublesome. The bobcat needs a battery now.
    “I've had a wonderful evening, but this wasn't it.” ~ Groucho Marx
Similar Threads
  1. battery corrosion/good battery dead now
    By mitchelli in forum Craftsman / Sears
    Last Post: 05-02-2010, 04:10 PM
  2. new battery???????
    By whitearrow in forum John Deere Owning/Operating
    Last Post: 06-18-2006, 11:23 PM
  3. Battery Tender vs Battery Minder
    By MikePA in forum Rural Living
    Last Post: 06-10-2005, 02:48 PM
  4. How do you know when you need a new battery?
    By Mith in forum General Lawn & Garden
    Last Post: 01-29-2005, 06:56 PM
  5. battery
    By alpha in forum Chinese Tractors
    Last Post: 01-29-2005, 08:28 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
