Results 1 to 4 of 4
01-31-2013, 12:42 PM #1Silver Member
- Join Date
- Apr 2012
- Posts
- 122
- Location
- Washington,Mo
- Tractor
- New Holland TC29,Ford Jubilee
2 Wheel drive truck tires
2007 F250 Superduty 4x2 super cab. Put two Cooper AT3's on rear about 6 months ago,now need two more tires.Want to be able to rotate tires,worth while putting same tire on front,note it is two wheel drive truck. Thanks,Tim
01-31-2013 12:42 PM # ADS
01-31-2013, 01:33 PM #2Super Star Member
- Join Date
- Jan 2007
- Posts
- 12,528
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
I would put the same. I did this on my BMW 335I. Wore out the rears a year ago so put on 2 Falkens. This year put 2 identical ones on. Had the new ones put on the rear and moved the year old ones with 15,000 miles to the front.
Now the trick is to get all 4 even.
Chris
02-01-2013, 01:35 PM #3Platinum Member
- Join Date
- May 2005
- Posts
- 967
- Location
- Eastern MA & Upstate NY
- Tractor
- John Deere 770, Bobcat 753
A heavy right foot?
“I've had a wonderful evening, but this wasn't it.” ~ Groucho Marx
02-01-2013, 04:32 PM #4
Re: 2 Wheel drive truck tires
I would replace the old two with the same as the new ones. I always replace all 4 at once. Also, I run all terrain tires. I have a 03 F250 2wd 7.3 and have BFG all terrains on it. Aggressive tires, but great when off road or in winter.
2007 JD 2305, 2008 JD 2520 w/200cx loader, Harbor Freight quick hitch, homemade pallet forks, 5' KK tiller, 5' KKxb disc, 4' landpride pulverizer, Frontier RB1072 blade, homemade 5 1/2' lawn roller at 3500lbs, 2005 John Deere 797 w/60" deck, 2009 John Deere 997 w/ 72" deck, 2005 JD HPX Gator w/power dump, 1998 Toro 455D 10.5' deck!
Similar Threads
Kubota L-3650 4 wheel drive front axle right wheel oil seal leak, how to replace?
By saxophobia in forum Parts/RepairsReplies: 4Last Post: 07-29-2012, 07:17 AM -
Switching from 4 wheel drive to 2 wheel drive
By casolorz in forum Kubota Owning/OperatingReplies: 31Last Post: 11-06-2011, 01:25 PM -
Traction Four Wheel Drive vs. Front Wheel Assist
By SEOhDave in forum Kubota Owning/OperatingReplies: 16Last Post: 09-23-2010, 09:29 AM -
Tires Front Tires for 2 Wheel Drive Loader work
By DIXIEDOG in forum Owning/OperatingReplies: 13Last Post: 01-20-2010, 10:30 PM -
Tires gear ratio for four wheel drive tires
By deerehoe in forum John Deere Owning/OperatingReplies: 1Last Post: 08-27-2005, 08:54 AM
