Page 6 of 20 FirstFirst ... 345678916 ... LastLast
Results 51 to 60 of 195
  1. #51
    Elite Member Deere Dude's Avatar
    Join Date
    Feb 2011
    Posts
    3,131
    Beaver Dam Wisconsin then to Hohenwald, TN
    John Deere 3720
    Default Re: Thieves love those trailer hitches!
    Traveling through Kentucky we dropped our fifth wheel off at a park and went to town. It was dark when we came back to the park which was about 5 miles from town and I thought I could see a glow off and on in the rear of the GMC Dually 4x4 truck. I was driving about 55-58 mph. After a little bit I told my wife to see if there was somebody in back of us and she said no. After looking more closely in the mirror it seemed like a little car was on my bumper, so close you couldn't see the car. I wanted to tap the brakes to let him slide under the truck a bit but I knew I didn't have a stinger in so I nixed that idea. Eventually I slowed gradually to 40 and he passed. When we got to our campsite in Florida I noticed a stinger with a 20,000# pintle loop on it laying in the weeds, probably from a utility worker of some sort, so I kept an eye on it. That thing is solid steel with a heavy duty plate on it for the hook. When I left a couple months later that came with me, and is on my truck almost all the time now. In the parking lots, I always park away from people, but they always seem to find me, but that pintle is impossible to miss so they stay back a little ways now.
    JD 3720 with R4s and bulldozer capabilities.
    X740
    13 Millimeter = 1/2"--------25 Milimeters=1"-----------100 Millimeter = 4"----------1 Meter = 40---------1 Kilometer = 3300' or 5:8 ratio
    A 13mm will but will be just slightly larger than a 1/2" nut.
  2. #52
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,625
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Quote Originally Posted by Bird View Post
    So if someone stops properly behind you, and then gets rear ended hard enough to knock him into you, you want to be sure and do the maximum amount of damage to an innocent motorist. That's a really nice attitude to have, isn't it?.
    that's what the car insurance policy from the guy that did the hitting is for.
    I don't see a moral problem leaving a hitch in. I have a farm. I'm probably pulling a trailer MOST of a week.. if not for home.. for work. I don't feel the least bit bad about leaving it in. The last person to hit mine was staring at the gps on his phone. No negative karma gained if there is no intent to cause wrong, even if a wrong is caused.
    ps.. if he's stopped far enough behind me.. and is rear ended HARD enought to move into me. my hitch into his hood is probably of no concern vs the back of his vehicle being flattened.
  3. #53
    Super Member texasjohn's Avatar
    Join Date
    Oct 2005
    Posts
    6,048
    Central Texas, Jarrell
    Kubota Grand L5030HSTC
    Drat, now you got me worried! I've got 4 vehicles with insert hitches and often leave the hitch in...guess I'll worry more about them...never lost one so far...
    Joy is having the tools you need and needing the tools you have!
    Kubota 5030 HSTC, BB, Danueser PHD, LA853 QA HD FEL w JD toothbar, 3pt chisel, 3 pt disk, 6' shredder, Kubota FEL hay spike, 3pt hay fork w carryall, Kubota RTV 1140
  4. #54
    Veteran Member Kernopelli's Avatar
    Join Date
    Oct 2006
    Posts
    1,847
    Carterville, Illinois
    Mitsubishi MTE2000D, Dig It 258 Backhoe Deere Z930M ZTR
    Quote Originally Posted by hodge View Post
    Can you share the rational on it being illegal in IL to leave the hitch in? I'm curious.
    Mine stays in, with a lock pin. I have the interchangable ball system ( 1 7/8, 2, 2 5/16- it works well), and have had no issue with the receiver freezing in the hitch. I know the hitch is there, and don't bang into it. I do take the gooseneck ball out, so that it isn't in the way when hauling flat stuff like plywood.
    My understanding was that it was pushed by the insurance lobby. Hitches cause more damage in rear end accidents supposedly. Good 'Ol Illinois.....Chicago rules the state and laws w/fines rule us! I Think it started Jan 1,2011 and is a $128 fine although I have never heard of anyone being cited locally, here is how it reads Statutes Amended In Order of Appearance
    625 ILCS 5/12-614 new
    Synopsis As Introduced
    Amends the Illinois Vehicle Code. Provides that if any portion of a motor vehicle hitch containing a ball mount and hitch receiver extends more than 4 inches beyond the motor vehicle's rear bumper, then the ball mount must be removed from the hitch receiver when the motor vehicle is not being used for towing. Provides that if any portion of a motor vehicle hitch extends more than 4 inches beyond the rear bumper of the motor vehicle and the hitch is composed of a single assembly that cannot be easily removed from the vehicle, then the ball of the hitch must be covered with a red cover. Defines "ball mount", "hitch receiver", and "motor vehicle hitch".
    Darryl
  5. #55
    Join Date
    Mar 2002
    Posts
    52,625
    Central florida
    Quote Originally Posted by xring100 View Post
    If you get rear ended from speed with a drop hitch in, it is a good way to do serious frame damage due to the huge moment arm involved I've seen crashes where the truck would have probably been better off with no hitch in. Especially if the cars bumper beam connects with the hitch. The hitch becomes a crowbar and your frame folds up like a pretzel
    Dave
    i have a tri and a 4 way mount as well. it's not a drop.. just a straight out. it is not one of the HF cheap ones for 5k it's spendy.. and yeah.. I use it as a step as my 350 and 450 are too tall to normally step into from the back
  6. #56
    Join Date
    Mar 2002
    Posts
    52,625
    Central florida
    Dave
    that's why I don't use a drop hitch.. only the straight out ones. and since it is a ford rcvr.. they aren't deep either.. so it is a short tounge. the rcvr on my old dodge and the yukon will swallow a LONG tounge ( yuck.. that just sounds bad ).. but the fords won't take but a few inches ( oh boy... getting pg13 here.. )
  7. #57
    Super Member timswi's Avatar
    Join Date
    Nov 2008
    Posts
    5,646
    Beaver County Pa
    Kubota BX23 TLB, Kubota RTV1100, Kubota Z724 & Polaris Sportsman 570 Touring
    Quote Originally Posted by Soundguy View Post
    This might be a first...A thread shut down for discussions about receivers and stingers...You were heading rapidly to NC17
    BX23TLB with 54" MMM
    RTV1100 with 72" Power Angle Plow
    Z724 ZTR
  8. #58
    Elite Member coobie's Avatar
    Join Date
    Sep 2004
    Posts
    4,036
    S.Michigan
    Kubota RTV 900, JD 740,Kioti DK 40 with KL401 loader .
    Quote Originally Posted by Diamondpilot View Post
    Guess that depends where you live and what they use on the roads. Also the lock brand and style have something to do with it. I have cut off my fair share.
    I will pass and just take it out like intended.
    Chris
    I live in southern Michigan but I do take mine off also when not in use.I use fluid film spray.coobie
    Kioti DK40se hst cab with KL401 loader,Kubota RTV 900,John deere X740,Kioti 73 inch tiller.Ingersoll 4020 3pt,troy bilt tiller,Billy goat brush cutter.
  9. #59
    Join Date
    Mar 2002
    Posts
    52,625
    Central florida
    Quote Originally Posted by timswi View Post
    well... I'm sure it won't be the first thread I've ever posted in that eventually got shot down.. er.. shut down..
  10. #60
    Gold Member cockeyedMFer's Avatar
    Join Date
    Jul 2011
    Posts
    270
    1959 MF 35 deluxe, gas
    Quote Originally Posted by KennyG View Post
    Better hope she doesn't read these threads.
    You've heard of trophy wives? I'm a trophy husband....but my trophy says Runner Up
    She just hasn't figured out that she got the short end of the deal yet!
Similar Threads
  1. I hate thieves!!!
    By Ridgewalker in forum Owning/Operating
    Last Post: 06-17-2013, 01:40 PM
  2. AARGH!-Thieves!
    By Blue Planet in forum Kubota Owning/Operating
    Last Post: 03-20-2012, 01:07 AM
  3. Thieves
    By tlbuser in forum Construction Equipment
    Last Post: 01-30-2010, 11:08 AM
  4. Apple thieves
    By homeinwestIL in forum Rural Living
    Last Post: 08-19-2009, 11:14 AM
  5. Beware of thieves
    By rcrcomputing in forum Owning/Operating
    Last Post: 03-03-2009, 08:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
