Page 1 of 4 1234 LastLast
Results 1 to 10 of 40
  1. #1
    Veteran Member brain55's Avatar
    Join Date
    Jan 2008
    Posts
    1,817
    Brentwood, CA
    Default
    This is what I am thinking about for my next truck.
    Starting to think about my next truck-pic_3351-jpg
    Hino 338CT
    I will be upgrading my trailer too since I have outgrown it already. For those that don't know. Right now I have a 2008 Ford F450 and a 28' gooseneck trailer that contains my mobile shop. I do on-site maintenance and repair for different businesses with construction and utility type equipment. Business has really taken off this year and I am asking a buddy of mine to come help me more and more often. The problem is my trailer isn't big enough for two people to work out of.
    I will likely move up to a 40' with dual tandem axles and air brakes if I move up to this style truck. I will also add bulk oil tanks and dispensers along with some other upgrades. My biggest problem with my current trailer is not enough storage space and it is tough for two people to work out of one toolbox.
    A little more background on my current truck. I bought it less than 2 years ago with 40k miles on it, it just turned 100k earlier this week. I could go spend another $40k on a used F450, $60k on a new one, either way they will be used up in 2-3 years or go buy a real truck that will last me 10 yrs. for $80k.
  2. #2
    Elite Member Dmace's Avatar
    Join Date
    Oct 2005
    Posts
    3,838
    Wakefield, NH
    Kioti CK20 HST
    Default
    Very nice!
    You know, that new RAM 3500 should be rated to tow 30,000 lbs. That should be plenty for that 40ft mobile shop. ;-)
    http://news.pickuptrucks.com/2013/01...30000-lbs.html
    Those GMC Kodiak trucks are nice for those big trailers too!
    Derek
    Kioti CK20HST
    KL120 FEL // KB2365 BH // 60" JRW 3ph snowblower // 48" HD Boxblade
    Sims-Cab Depot heated cab
    Quote Originally Posted by DiamondPilot
    Now it's time for Ford and GM to step up
  3. #3
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default
    For towing that type of load you are doing the smart thing. No way any of the big three can stand up.
    Getting a chassis with a tranny to match is the key.
    Chris
  4. #4
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,195
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    Default Re: Starting to think about my next truck
    Will you have/need 4x4 (I guess 6x6 actually unless you run super singles) for this truck?
    Aaron Z
    A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
    Robert Heinlein, Time Enough for Love
  5. #5
    Join Date
    Sep 2009
    Posts
    183
    Well... permanent adresses is Bonaventure, Eastern Quebec, Canada
    White LT 18hp B&S old beater
    Default
    Do you need a 4x4? International is making a nice 4x4 hauler
    http://www.dieselpowermag.com/featur...k/viewall.html
    Life is Highway. One day, I will retired at home.
  6. #6
    Join Date
    Jan 2008
    Posts
    1,817
    Brentwood, CA
    Default
    I'd like to have 4wd but the direction my business has gone I can get by without it, I hope!
  7. #7
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,195
    Quote Originally Posted by brain55 View Post
    If not, you can always tow yourself out with the machine you just fixed right?
    Aaron Z
  8. #8
    Join Date
    Jan 2008
    Posts
    1,817
    Brentwood, CA
    Default
    Quote Originally Posted by Diamondpilot View Post
    Chris
    Considering my current trailer with everything in it weighs 17k lbs I'm guessing moving up to the bigger trailer it could weigh in the 25k lb range.
  9. #9
    Veteran Member YesDeere's Avatar
    Join Date
    Dec 2008
    Posts
    1,140
    Merland
    Default
    I have read a lot of your threads/posts and I think you are going in the right direction. It just makes sense. Sure your current setup works but that is a lot of weight and abuse. I think going bigger with a more commercial machine will save money in the long run. We have had great luck with our Hino's, plus they stand behind them. 5 year 250,000 mile on drivetrain and emissions. When they were having injector problems they extended it to 5 year unlimited miles on the effected models. Who else does that? Plus we are averaging 9 mpg on 20 foot reefer box trucks that gets overloaded regularly. Whatever you decide good luck!
  10. #10
    Elite Member
    Join Date
    Mar 2010
    Posts
    2,631
    Ontario
    CT235
    Our 4400 series IH gets the same fuel economy as our old F550 for what it's worth. Biggest benefit in going up in chassis size are the brakes and visibility. Plus it has a smaller turning radius than the smaller truck. Make sure you check into yearly fees and mandatory inspections whichever way you go.
    Tim.
Similar Threads
  1. Ever used starting fluid in your truck?
    By JDgreen227 in forum Trailers & Transportation
    Last Post: 10-13-2011, 09:57 PM
  2. Starting to think about a newer truck
    By hrcarver in forum Trailers & Transportation
    Last Post: 09-24-2010, 06:57 PM
  3. Jump Starting Farm Truck from Kubota
    By hcody in forum Kubota Owning/Operating
    Last Post: 12-23-2009, 11:19 PM
  4. Starting old farm truck
    By FSC in forum Construction Equipment
    Last Post: 07-18-2005, 05:13 PM
  5. Diesel truck starting to look more attractive
    By Mosey in forum Related Topics
    Last Post: 05-19-2004, 10:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
