Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Join Date
    Sep 2012
    Posts
    104
    South of Mason Dixon
    Massey Ferguson 2615L
    Default 2014 ford super duty
    I am really tickled with my 2011 Ford f250 4x2 lariat currently at 51000 miles 6.2 gas engine.
    It has had 5 oil changes, the tires have been rotated and balanced every 12k -15k miles, 2 air filters they just never got really dirty,I had to replace the Battery which is my fault I leave my key on accessory a lot, thanks to sirius. That is all the maintenance that has been done and or needed. I performed all but the tire balancing myself. I use Mobil 1 EP.
    After owning diesel trucks for a long time I chuckle to myself everytime I fill up with fuel.
    So I have been thinking what could Ford do to improve this truck?
    Probably my biggest complaint is the transmission gearing, tranny is just too wide ratio. I dont want to be in third gear when I hit the speed limiter at just under a 100, lol. Want to be in fifth gear with OD still remaining. So tightening up the ratios in the tranny would be really good.
    The 6.2 is a super smooth engine with good power, but what if? Ford applied the Ecoboost technology to this engine i see an easy 500 ft lbs of torque gas motor that will still get decent mileage and have tremendous pulling power coupled with a properly geared tranny.
    The final driveline mod would be to add supplement air bag suspension to at least the rear, instead of a superstiff unloaded ride.
    As far as the interior I have the Lariat and believe that truck leather should be more of a saddle grade (thicker) but still black. Also a glovebox light, some footwell lighting, and maybe even a reflector on each door for added safety in parking.
    Anyone else have any suggestions we should send to Ford?
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Elite Member Dmace's Avatar
    Join Date
    Oct 2005
    Posts
    3,838
    Wakefield, NH
    Kioti CK20 HST
    Default
    Out of curiosity, what fuel mileage have you seen empty?
    So far that 6.2l sounds like a great engine!
    They seriously need a new exterior design.
    Derek
    Kioti CK20HST
    KL120 FEL // KB2365 BH // 60" JRW 3ph snowblower // 48" HD Boxblade
    Sims-Cab Depot heated cab
    Quote Originally Posted by DiamondPilot
    Now it's time for Ford and GM to step up
  4. #3
    Join Date
    Apr 2011
    Posts
    594
    Boston
    L3700SU
    Default Re: 2014 ford super duty
    I had a 2011 SRW reg cab 4x4 350 that got about 13.5 empty. I now have a 12 f150 4x4 crew with the 6.2 and it just about the same.
  5. #4
    Join Date
    Apr 2011
    Posts
    594
    Boston
    L3700SU
    My .02..... The seats in the super duty are horrible. My 06 Super Duty was far more comfortable than my 11.
  6. #5
    Super Member CompactTractorFan's Avatar
    Join Date
    Jul 2010
    Posts
    7,946
    Pennsylvania
    Kubota BX25
    Quote Originally Posted by Dmace View Post
    I like the design except for the angled headlights...ewwww...
    But that is a nice truck!
    Kyle - CompactTractorFan
    Kubota BX25 w/R4's (23 hp, 17.7 PTO hp), Loader, Backhoe, 60" Mid Mount Mower, Cyclone Rake Z-10 Lawn Vacuum, CountyLine Carryall, Ferris 48" Walk-Behind Mower, Honda 21" Walk-Behind Mower, Mighty Mac 4" Chipper/Shredder,
    2000 Dodge Intrepid, 2012 Ford F-150 EcoBoost
  7. #6
    Join Date
    Sep 2012
    Posts
    104
    Have the 3.73 rear diff. Empty mpgs are 17-18 hwy, and 14-15 city, Towing 10k+ interstate 7-8mpg, rural roads 9-10 mpg.
    The 4 x 4 really seems to suffer in the mpg dept. All of my past diesel 4 x 4 s averaged 14 or less empty, and 10 loaded.
    I decided i just would not go anywhere i could get stuck, and so far have only had one instance requiring assistance to keep her rolling.
  8. #7
    Join Date
    Apr 2011
    Posts
    594
    Boston
    L3700SU
    Quote Originally Posted by teampryor View Post
    4x2 or 4x4?
  9. #8
    Join Date
    Sep 2012
    Posts
    104
    4 x 2
  10. #9
    Join Date
    Oct 2005
    Posts
    3,838
    Wakefield, NH
    Kioti CK20 HST
    Default
    Not bad at all. Beats the cost of diesel.
    Derek
    Kioti CK20HST
  11. #10
    Platinum Member crashz's Avatar
    Join Date
    May 2005
    Posts
    968
    Eastern MA & Upstate NY
    John Deere 770, Bobcat 753
    Default
    I'm glad the new 6.2L engines are working out. I tried a 2010 model that was exceptional, and nearly pulled the trigger on it, but on my test drive, there was an on-ramp at the steep incline. The 5.4 had to scream to accelerate to hwy speeds, so I was turned off by that.
    I would have bought an F350 last year, but I don't care for the newest styling as much and love the current GM truck style. That and GM incentives with loyalty was just a little bit better.
    Thanks for the update on mileage. Doesn't seem like there are to many TBN members with the new gas Superduties, so this is great for folks who are researching new trucks.
    BTW - I'm a Sirius XM junkie now too.
    “I've had a wonderful evening, but this wasn't it.” ~ Groucho Marx
Similar Threads
  1. 2011 Super Duty
    By dgl24087 in forum Trailers & Transportation
    Last Post: 12-24-2011, 08:01 AM
  2. Ford Super Duty 6.2L Mileage?
    By crashz in forum Trailers & Transportation
    Last Post: 11-07-2011, 09:14 PM
  3. SUPER DUTY CUTTER??
    By Giles in forum Attachments
    Last Post: 08-28-2010, 08:51 AM
  4. Ford Super Duty
    By KB9UDE in forum Trailers & Transportation
    Last Post: 06-10-2010, 08:23 PM
  5. What's With the Ford Super Duty Pricing?
    By Haoleguy in forum Trailers & Transportation
    Last Post: 06-01-2007, 01:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
