Results 171 to 180 of 253
02-16-2013, 08:38 AM #171Super Member
- Join Date
- Mar 2008
- Posts
- 6,619
- Location
- Northern Fingerlakes region of NY, USA
- Tractor
- Kubota L3830GST, B7500HST, BX2660
Re: Ram 1500 first modern half ton to offer diesel
These questions should not be assessing our students’ ability to decipher convoluted language. Instead, they should be assessing deep understanding of core concepts.
http://www.washingtonpost.com/blogs/...-tests-failed/
02-16-2013 08:38 AM # ADS
02-16-2013, 08:46 AM #172Platinum Member
- Join Date
- Oct 2005
- Posts
- 735
- Location
- Southern Indiana
- Tractor
- Kubota/B7800
02-16-2013, 08:57 AM #173Platinum Member
- Join Date
- Oct 2005
- Posts
- 735
- Location
- Southern Indiana
- Tractor
- Kubota/B7800
02-16-2013, 09:55 AM #174Veteran Member
- Join Date
- Sep 2005
- Posts
- 1,193
- Location
- Ohio
- Tractor
- Case DX55, Ford 850
After years of people asking for a diesel in a half ton, and saying they will buy the first one that comes out, who plans to follow through? Who plans to pay the $4500 premium over the new Pentastar that gets similar MPGs. Who on this thread definitely plans to buy one and can report back on their purchase come 3rd quarter (July)? I think the only way to justify a diesel in a half ton is if you tow heavy and tow daily though. I'm curious since now that Ram delivered on all this great little Italian diesel, we now hear guys say they will wait for GM to build one, and THEN they will definitely buy it. So, who's in?
02-16-2013, 09:55 AM #175Super Member
- Join Date
- Mar 2008
- Posts
- 6,619
- Location
- Tractor
Thats the pump prices around here. We have spendy fuel due to high taxes.
Will be interesting to see what it gets when some of the magazines get some test trucks and tow with them. Pretty much anything mileage wise is a guess at this point.
Aaron ZThese questions should not be assessing our students’ ability to decipher convoluted language. Instead, they should be assessing deep understanding of core concepts.
02-16-2013, 10:05 AM #176Veteran Member
- Join Date
- Sep 2005
- Posts
- 1,193
- Location
- Ohio
- Tractor
While the Ecoboost has over 50% more HP (365), it is at high RPMs. But it does get most of the 420 ft lbs down real low. I think the Ecoboost will walk all over this new diesel with power but the diesel will kill the Ecoboost for MPGs if most of your driving is while towing heavy. For that matter, this diesel will beat ALL gasers for MPGs when towing heavy.
02-16-2013, 11:04 AM #177Veteran Member
- Join Date
- Mar 2009
- Posts
- 1,067
- Location
- Lee, IL
- Tractor
- John Deere 1070
Resale at this point I think is a to be undetermined. If these engines turn out to be POS, resale will not be high.
I also don't understand why everyone is so excited to buy a half ton with a diesel for heavy towing, if you are towing that much why wouldn't you just buy a 3/4 ton?
02-16-2013, 11:10 AM #178Platinum Member
- Join Date
- Oct 2005
- Posts
- 735
- Location
- Southern Indiana
- Tractor
- Kubota/B7800
Yes, I agree.
I think the fact the ecoboost has a longer, wider rpm range with the available torque will more than make up for the two fewer gears. One will have to sacrifice acceleration for fuel efficiency. Anxiously awaiting some torque curves unless someone already has access to one.
02-16-2013, 11:35 AM #179Super Member
- Join Date
- Mar 2008
- Posts
- 6,619
- Location
- Tractor
02-16-2013, 11:55 AM #180Super Star Member
- Join Date
- Jan 2007
- Posts
- 12,529
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
I think you guys are in law law land. I have personally ownded about 15 trucks in my life time, 4 were diesel. My customers are about 1/2 gas and 1/2 diesel owners. No matter gas or diesel you put 75% the tow capacity behind a truck you are going to get roughly 1/2 the unloaded mpg.
Take my two current trucks. My 06 F350 will do 23.6 mpg at 75 mph unloaded. Throw my current big boat behind it and it gets about 14 mpg.
My other truck is a 08 Nissan Titan. It gets about 16 mpg at 75 mph. Throw my smaller boat behind it and it gets right at 9 mpg.
Why a diesel really shines is the Turbo. Same benefit can be seen with a gas engine and a turbo. They allow the engine to make full HP as temperature and altitude change. Remember that stated HP and TQ numbers per SAE Ratings are done at sea level and 15 deg Celsius (59 deg Fahrenheit). Every 1000' of elevation change makes you lose about 3% of your power. That means a guy with a 300 HP truck at Denver, about 6000' elevation, will lose 18% power to start with if its the same 59 deg F. Thats nearly a 55 HP loss. Now factor in temp and as it gets hotter performance falls again.
Temp plays a big part and is part of the reason you see a loss in fuel economy in the winter and a gain in the summer. Cold air is more dense and has the ability to make more power which takes more fuel. Vise versa in the summer.
What a turbo does is normalize things. The first turbo systems were actually marketed as "Turbo Normalizers".
Yes a diesel does a good job at making low end torque but its less a advantage today when compared to todays direct injected gas engines like the Eco Boost, ect.
Chris
Similar Threads
2005 chev. 4x4 1500 (half ton) need HELP
By duke7595 in forum Trailers & TransportationReplies: 10Last Post: 04-02-2012, 08:28 PM -
RAM 1500 Diesel option still alive
By Dmace in forum Trailers & TransportationReplies: 50Last Post: 01-15-2011, 07:52 PM -
Beefing up half-ton for gooseneck
By Negligence in forum Trailers & TransportationReplies: 159Last Post: 05-18-2009, 06:55 PM -
Half ton vs 3/4 ton pickup?
By Boondox in forum Related TopicsReplies: 56Last Post: 03-06-2009, 11:31 AM -
Half-ton truck comparison
By davkir in forum Trailers & TransportationReplies: 11Last Post: 11-19-2008, 01:49 PM
