Well I do know a thing or two about engines and engine design. While I has less experience with diesels as an aircraft mechanic, I have some knowledge of their operation. Please explain why a Diesel engine is built much heavier than an equivalent gas engine. The higher compression adds a lot of stress is the reason. The ecoboost with direct injection allow the computer to control the timing of injection of the fuel and alter the burn cycle and the stresses of the explosion. That is how they get away using 87 octane pump gas without preignition.
Yes, I know you would like for them to tune a little more torque to be able to say they have the best torque. As mentioned, the 2013 ecoboost has compressors that are 3 mm larger. The current injectors are good for 500 HP. Simply tune to the computer and achieve more output.
There are guys running 12's in 1/4 mile with Ecoboost F-150's with just basic bolt on's.
