Results 21 to 30 of 39
02-28-2013, 08:03 PM #21Platinum Member
- Join Date
- Nov 2010
- Posts
- 571
- Location
- Marshall Texas
- Tractor
- Kubota L4400
Re: Tandom trailer blowout
This is true.. ! We just had a guy accidentally touch an aluminium air pipe on an engine.... pipe looked just like everything else on the engine. Problem was, it was on the outlet side of the turbo before the CAC.... pipe was about 350-360 degrees!. Hes sporting a nice burn right now!
Kubota L4400 GST
03-05-2013, 07:07 PM #22
Re: tire pressure monitoring systems
Thanks for the heads up. I knew these existed, but this thread convinced me to spend the dough for the added safety value on a long trip we'll be undertaking this summer. I looked at the variety of brands/models available, ended up going with the TST 507 with flow through sensors. Now i should upgrade my stems and be good to go.
03-05-2013, 08:08 PM #23
I keep one of these trailer aids in my truck. Works great with my horse and flatbed dual axle trailers. Lot simpler than another jack.
'06 Mahindra 3215HST,KMW ML111 FEL,BushHog SBX65 Boxblade,BushHog RZ160 Rotary Cutter,Kasco KOS604 Seeder,Cosmo 250 3PT Spreader,Southern 6' Landscape Rake,Rhino LR 6' Rear Blade
03-05-2013, 08:16 PM #24Platinum Member
- Join Date
- Nov 2010
- Posts
- 571
- Location
- Marshall Texas
- Tractor
- Kubota L4400
03-05-2013, 08:22 PM #25Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,111
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
you know.. i've been threatoning to get one of those. may have to finally make good on my threats...
03-05-2013, 08:29 PM #26
03-05-2013, 08:36 PM #27Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,111
- Location
- Central florida
- Tractor
nice setup! what's the weight rating?
03-05-2013, 08:50 PM #28Super Star Member
- Join Date
- Jan 2007
- Posts
- 12,469
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
Just be careful using a ramp. I have seen it bend a spindle on the good axle due to overloading. It was so bent we could not get the rear bearing off. Had to cut it off then load the trailer on my GN and take it to a fab shop to have the spindle cut off the axle tube and a new one welded in.
Chris
03-05-2013, 08:58 PM #29Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,111
- Location
- Central florida
- Tractor
yikes!
so far my hi-lift farm jack and or 50t bottle jack and timber have been doing the job... hmm.....
03-06-2013, 08:48 AM #30
Similar Threads
trailer tire blowout
By radioman in forum Trailers & TransportationReplies: 14Last Post: 04-15-2009, 09:01 PM -
TC35D PTO Blowout!
By JDDan in forum New Holland Owning/OperatingReplies: 6Last Post: 06-13-2008, 11:12 PM -
Tire blowout - long
By Tdog in forum Related TopicsReplies: 16Last Post: 10-23-2007, 11:37 AM -
PLEASE HELP, NEW TRACTOR, HYDRAULIC BLOWOUT
By EastTnFarmboy in forum HydraulicsReplies: 18Last Post: 09-25-2007, 10:40 AM -
Please Help, New Tractor, Hydraulic Blowout
By EastTnFarmboy in forum Owning/OperatingReplies: 13Last Post: 09-24-2007, 10:04 PM
