Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 56
  1. #31
    Member PAlittleKub's Avatar
    Join Date
    Oct 2012
    Posts
    26
    Central, PA
    Kubota BX1860
    Default Re: Single axle trailering of a CUT
    I have a question to add to this post if anyone would be able to help me answer I would greatly appreciate it! I just bought a new BX1860 with FEL and MMM and am hoping to buy a utility trailer to tow it to be serviced and help out family at their land. I have a new Jeep Liberty with a hitch and hoped to get a single axle trailer. I will mostly use the trailer for mulch and landscaping around my property. Will a single axle trailer be strong enough to tow my tractor on occasion??? Thanks for the help!
  2. #32
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    single axle trailers are pretty non-ideal for much larger than grass cutting machines. IMHO
    I cannot reccomend a single axle trailer for a tractor.
    CAN it work? maybee / possibly , depending on all particulars. Ideal? doubtfull.
    for one.. in a smaller weight class of trailers.. you don't get nice things like brakes.. and floor options are usually expanded metal and light duty gates instead of ramps and solid flooring.
    good luck..
  3. #33
    Super Member Scooby074's Avatar
    Join Date
    Aug 2006
    Posts
    6,565
    Nova Scotia
    BX 25, ZD 326
    I haul my much lighter BX on a 3500# single axle and it's sketchy as ****. I only go the 25 KM between my place and dads too.. I couldnt imagine a heavier tractor on a longer journey.
    An upgrade is definitely in the cards for me.
  4. #34
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default
    Even though your little tractor is only 2000# with the loader and mmm mower I would not do it. Your liberty probably has tow rating of 5000# so I would get a 16' tandem axle landscape style trailer.
    Chris
  5. #35
    Join Date
    Oct 2012
    Posts
    26
    Central, PA
    Kubota BX1860
    Default
    That's sort of what I was afraid of. I didn't really want to get a dual axle if I didn't have to. It has to be inspected and I'll have to put a brake controller on the Jeep too, and I won't be transporting the tractor on it much. Mostly used for mulch and other things around the home.
  6. #36
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Default
    Quote Originally Posted by PAlittleKub View Post
    If I am going more then 5 miles I have found its much quicker just to drive my tractors. In reality, by the time you hitch up, check the tires, get the ramps out, load the tractor, chain up, drive there, then repeat the process it takes a hour.
    Chris
  7. #37
    Veteran Member deepNdirt's Avatar
    Join Date
    Sep 2009
    Posts
    2,315
    Nth East Ga, USA
    yanmar YM-1700
    You may well find a single trailer built heavy duty enough to hold a small tractor, However it is not always the payload you have to consider, They're many other factors, such as it having no brakes, difficult to know where and how to distribute the weight? yes you might start out thinking you have the weight of the tractor perfectly balance over the axle however that weight can suddenly be transfered to the rear of the tow vehicle when having to unexpectedly hit the brakes, The momentum and extra weight will slam the rear of the vehicle down resulting in lifting the front of the vehicle and will not have adequate braking, remember the largest part of your braking comes from the front brakes of you vehicle, The next scenario could be while towing up an incline the weight then shifts to the rear resulting in tongue lift and lifting of the rear of the tow vehicle then loosing traction, and now fro the 3rd scenario, (Jack-knife ) is always a possibility in towing both dual and single axle trailers, But at least with having a tandem axles the weight is over the TWO axles and will have a safer chance of getting your rig stopped,
    If reasons for think and wanting to use a single axle trailer are to prevent over loading the tow vehicle, Your wrong, You should use a lighter built tandem if need be instead of a heavier built single axle trailer, The rule is, It's better to have More and not need it, than to need more and not have it, You can find smaller 5x10 ft tandem trailer, actually I had one and sold it due to obvious reasons of needing a larger trailer,
    Attached Thumbnails Attached Thumbnails Single axle trailering of a CUT-picture-176-jpg
    Never judge a man until you've walked a day in his shoes,
  8. #38
    Platinum Member Notforhire's Avatar
    Join Date
    Nov 2011
    Posts
    853
    Southwestern Virginia
    JD 5055E
    About 40 years ago the company I worked for, had a low tilt bed trailer that they used to transport an International Hough payloader. It was single axle trailer, and worked fine.
    It had 20 inch wheels and was towed behind a 10 ton truck with air brakes.
    It makes a big difference how big the tow vehicle is, as to what you can tow too.
    Bill
  9. #39
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    Quote Originally Posted by Notforhire View Post
    Bill
    yes it does.
    the one time i hauled a tractor on a single axle I was pulling with a ranger.. it was a uncomfortable experience. had that been behind my f450 drw.. I'm sure I wouldn't have noticed an issue..
    for the OP.. i'd rent a wet brake uhaul tandem before i'd pull single. your call.. be safe.
  10. #40
    Veteran Member Gem99ultra's Avatar
    Join Date
    May 2009
    Posts
    1,155
    Mid-Georgia
    Kubota L3400HST
    I suppose you've considered hiring it hauled instead of ramping up to do it yourself? Somebody like U-Ship can haul it for what it'll cost you in fuel and expenses, not to mention two nerve racking days of driving time.
Similar Threads
  1. Skid steer on a single axle
    By 94BULLITT in forum Trailers & Transportation
    Last Post: 08-12-2012, 07:36 AM
  2. Dual Axle or Single?
    By Beltzington in forum Trailers & Transportation
    Last Post: 03-20-2012, 06:41 PM
  3. Properly securing a CUT for trailering
    By dirtwhisperer in forum Owning/Operating
    Last Post: 09-09-2004, 02:20 PM
  4. B7500 & Single axle trailer
    By BILLMAN in forum Trailers & Transportation
    Last Post: 11-09-2001, 06:01 PM
  5. B7500 & Single axle trailer
    By BILLMAN in forum Kubota Owning/Operating
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
