Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 45
  1. #31
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,993
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Default Re: stand up or slide in ramps
    Quote Originally Posted by 930ck View Post
    Need a trailer to haul my kubota 5740 and had originally thought about a trailer with 5200 # axles but for a few hundred more I decided to go with a 14000 # 18+2 dovetail (may need to haul broken vehicles) trailer. Leaning towards getting the stand up ramps but was curious what others opinion was. Trailer will be used most for hauling tractor .
    Did you get a trailer?
  2. #32
    Veteran Member powerstroke444e's Avatar
    Join Date
    Jan 2008
    Posts
    1,230
    Near Springfield IL
    mostly orange
    I had a 16 and 22' trailer one with fold up and one with detached ramps that are just stored were every I could find, sold both and looking for a full tilt equipment trailer. I have looked at about everything out there and I am leaning towards Econoline Trailers - Viewing 6 Ton Mini-Max® Tilt(13,800# GVWR) Technical Specifications
    as the deck height is only 27"
    Good luck on your search
    If it ain't smokin' it's broken.
  3. #33
    Join Date
    Apr 2012
    Posts
    134
    southcentral kansas
    allis d 17/ case 930, 1370/ kubota L5740
    Default
    Quote Originally Posted by Xfaxman View Post
    Haven't got one yet but have read and reread everyones replies, I agree a tilt bed trailer would be the handiest but after the tractor purchase and still wanting a few attachments I need to scale back some. Still leaning towards the stand up ramps but everyone brought up valid pros and cons of each design.
  4. #34
    Join Date
    Feb 2013
    Posts
    7,993
    Meridian, OK
    I think this is the most versatile design. The ramps can stand up, or lay down and the dovetail can pop-up if needed.
    stand up or slide in ramps-p9062364-jpg stand up or slide in ramps-p9062369-jpg stand up or slide in ramps-p9062372-jpg
  5. #35
    Join Date
    Apr 2012
    Posts
    134
    southcentral kansas
    Default
    <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=310762"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=310763"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=310764"/>
    I will agree with you on that ramp setup just a little more trailer than I could handle.
  6. #36
    Join Date
    May 2009
    Posts
    942
    South Mississippi
    2008 John Deere 5303 MFWD
    Default
    Quote Originally Posted by powerstroke444e View Post
    After spending a couple years with my stand up ramps I can say there have been a few times I wished they were not there. Examples are when hauling tractor with rotary cutter and disc harrow. With these two loads and length of trailer, it would be better if I could shift the load to the rear 2-3 feet. I do not currently use a load distributing hitch and that may help/resolve the issue I have of too much tongue weight. I like the idea of the over the tires bed which could be an issue, but hasn't so far. My initial concern with a tilt was if wanting to carry an extra implement and the tractor. I suppose if extra attachment was properly tied down it really wouldn't be affected by the tilting. Other concern would be the pintle hitch. Not real common on trailers towed by pick ups. Common on trailers we use that are towed by larger trucks. See them alot on dump trucks.
  7. #37
    Join Date
    Apr 2012
    Posts
    134
    southcentral kansas
    Default
    Went ahead and bought a PJ 14000# 18' +2' dovetail with standup ramps. The ramps are spring loaded with a double hinge so if the trailer is empty they can be laid down on the dovetail. Told salesman that I was still on the fence regarding the ramps and he told me that since it was more of an equipment trailer he sells very few with slide in ramps. Plan on keeping the trailer a long time so resale is not a major concern but you never know. Since I have to haul the tractor to where I need to use it, plan on just leaving it on the trailer and keeping them both in the shed. Now the only decision to make is which fel grapple to get!
  8. #38
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default
    The RULE is without pictures it did not happen.
    Chris
  9. #39
    Join Date
    Apr 2012
    Posts
    134
    southcentral kansas
    Default
    Didn't think to take pictures before parking it inside, tried to take some tonight but no success yet on posting them.
    Attached Thumbnails Attached Thumbnails stand up or slide in ramps-forumrunner_20130413_221322-png
  10. #40
    Join Date
    Apr 2012
    Posts
    134
    southcentral kansas
    Default
    I guess I did get one attached
Similar Threads
  1. Do you like slide under ramps?
    By Charlesaf3 in forum Trailers & Transportation
    Last Post: 03-19-2011, 04:19 PM
  2. How to make ramps stand up on gooseneck
    By Newblue in forum Trailers & Transportation
    Last Post: 02-02-2010, 10:09 AM
  3. Mowing the slide?
    By JazzDad in forum Safety
    Last Post: 06-20-2007, 12:51 PM
  4. Backyard slide
    By Tractors4u in forum Photos
    Last Post: 11-01-2004, 08:01 PM
  5. Took a slide today!
    By Anonymous Poster in forum Safety
    Last Post: 11-25-2002, 12:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
