Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 44
  1. #31
    Gold Member Todd727's Avatar
    Join Date
    Apr 2012
    Posts
    396
    Holly Springs, MS
    CaseIH Maxxum 115
    Default Re: Would you haul anything on this trailer?
    Quote Originally Posted by JJZ 109 View Post
    He must have a license to pull doubles.
    Don't need a license in many places to pull a double.
  2. #32
    Join Date
    Jul 2004
    Posts
    1,986
    Bancroft, Ontario
    JD4300
    You use the bucket to shove down the hind end of the 2x10ramps then drive up until they flip back up. Stick on some red flags, chains, binders and off you go...
  3. #33
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    plenty of red flags come to mind hauling with that.
  4. #34
    Super Member clemsonfor's Avatar
    Join Date
    Sep 2009
    Posts
    8,592
    Greenwood Co., SC
    Yanmar YM2000
    Quote Originally Posted by Coyote machine View Post
    Only huge oversized loads, unsecured of course, and with little or no weight over the tongue with the tires mixmatched and under inflated!
    BTW, the recxeiver hitch is for adding various other trailers behind the main trailer- DUH!
    Oh yeah, how much?
    This is hilarious that only someone on here or like us would get !!
    YM2000. MF dirt scoop,4' Jbar bushhog,boompole, LMC 12-16 disk harrow, 4' Atlas boxblade (with rippers). 1980 chevy K10,1990 ford ranger 2wd (285K miles),1997 saturn SL2 (twin cam!!),2001Toyota Higlander
    1986 Cobia 177 sunskiff w/1981 Johnson 60 hp
    1991 Javalen 17ft w/same year 150 Johnson GT
    Troybuilt 4 cycle & Echo 2 stroke,cold natured(need carb rebuild),MS390 Stihl, Northern tool pressure washer, mixes water into the oil in the pump(now dead, motor on a tiller). 5000 watt generator.
  5. #35
    Super Member Coyote machine's Avatar
    Join Date
    May 2009
    Posts
    7,510
    Southern VT
    '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Mower. Diamondplate aluminum canopy.
    What? You mean this is not a normal trailer?
    2010 DK-40se/HST, KL-401 FEL, (reversible cutting edge). Titan Tree Shear. 72" Ratchet Rake. Fit Rite: Top-N-Tilt hydraulics & diverter. HLA Series 2000 7' plow, Aquiline MPC rear chains. Samuri Sickle bar.
    2016 Mechron 2200PS. 2016 Cub Cadet Pro Z 160 AW Steering, Kawa 23.5HP. 2015 Husky 322T AWD Rider, Combi 103 deck. Dr. Brush mower, & 42" lawn deck, & Dr. 6.5HP Trimmer/mower.
    Bunch of STIHL chainsaws: 011x 2, MS192T, MS200T, MS180C, MS230, MS270 (Wood Boss), 038 Farmboss.
  6. #36
    Bronze Member ghenges's Avatar
    Join Date
    Apr 2012
    Posts
    93
    Greensburg PA
    Farmall
    Quote Originally Posted by kebo View Post
    If you would, then it's for sale on CL!! How much weight can three 2x10's stacked onto each other hold at the end of the leverage point? I wouldn't want to try and find out.
    Attachment 307626
    How much weight could 3 stacked 2x10's hold at the end of the leverage point? The entire weight of an automobile could be placed at the very end, however when loaded there will be zero weight at the end of the triple stacked 16 foot pressure treated SYP planks.
    I pondered what is the purpose of the triple stacked lumber since a loading ramp extension could be easily accomplished with a single plank.
    I think the triple stack is so the doors of the cars can open above the fenders.
    Cripes, today's cars only weigh 3000-4000 pounds,
    this trailer (although it is certainly a bastardlashup) is a perfectly safe and of adequate strength to accomplish the task. I wouldn't be afraid to haul a full sized pickup truck on it.
    The only thing it needs is a light bar (w/ side markers) hung on the furthermost back end of the planks to make it street legal..
    By comparison, look at the trailers that Lowes, TSC, etc. offer for sale, this ugly trailer is far and away stronger than the chintzy built crap trailers from Lowes.
    "I know the end of humanity is near when my tractor comes with a place to store and plug in a cell phone, but no tool box" -- God's Country
  7. #37
    Platinum Member Iowan's Avatar
    Join Date
    Oct 2012
    Posts
    713
    North Central Iowa
    Kubota's
    A normal trailer has one flat tire.
  8. #38
    Veteran Member CliffordK's Avatar
    Join Date
    Mar 2013
    Posts
    1,202
    Eugene, Oregon
    Toro D200, Ford 1715, International 884,
    The steel tread in the trailer at the beginning of the topic will also give one some strength near the ends of the planks. I agree that it looks funky, but I'm sure it does its job as long as the load is tied down well. It just needs lights closer the the back of the trailer, and perhaps flags on the ramps.
    Quote Originally Posted by ghenges View Post
    Each type of trailer has its place.
    I showed you a photo of my "car hauler".
    And, rake hauling trailer
    Haulin brand was originally sold by Home Depot, I think.
    It is a HUGE step up from the Harbor Freight version. I find it is an excellent little utility trailer. I've never installed a jack because I usually just grab the chains and move it around by hand.
    The little 8" tires are rated at an incredible 910 lbs each.
    I haven't mounted the replacement tires yet, rated at 1073 lbs each.
    I find it is an excellent little trailer and performs its job admirably.
    The only complaint that I have had about it is that the tongue was originally only attached to the first and second cross members, the second being a piece of bent channel iron. After almost loosing the tongue, it is now welded to the first, second, third, and fourth cross members (3/4 the length of the trailer), and has the bulldog hitch. I welded both ends of it before I realized that I had made it too long, but I kind of like it long.
    I occasionally get comments about the soda cans.
    Anyway, I haven't tried the new generation of big box store trailers, but the mid 1990's model I have has done quite well as a small general purpose utility trailer.
  9. #39
    Join Date
    Apr 2012
    Posts
    93
    Greensburg PA
    Farmall
    Quote Originally Posted by CliffordK View Post
    Wasn't particularly dissing these big box store trailers.
    I own a 6x8 foot TSC trailer myself, they are indeed cheep & chintzy, they sell enough of them so their liability carriers evidently are satisfied with the adequacy of the engineering and construction. Still I feel somewhat uncomfortable towing something built to the minimum standard..
    Handy and light though, just throw it up into the truck bed when going to pick up something (I hate the bouncing when empty on these rough PA roads).
  10. #40
    Gold Member
    Join Date
    Aug 2008
    Posts
    373
    Darlington, SC
    1957 Ferguson 35, 1977? Yanmar 2200, 1963 Cub Cadet Original
    Would I use the trailer as it sits now? NO. But it does have a lot of potential to be converted into a nice trailer of some sort.
    Look at the length of the trailer and then look at the balance point. There is a lot more wood sticking out behind the axles than in front of them. I think instead of having fold down ramps he had "stick straight out the back ramps". My FIL bought a trailer years ago that was built like this, although it was welded steel, not wood) to haul his riding mower on. He had 4 different properties to mow and his was a tilt back. When connected to the truck, tilt unlatched, nothing on the trailer, it stayed in a tilted position, slightly heavier in the rear. When you drove up on the trailer, the weight of the mower tilted it forward/down. You could tilt it down with two fingers, well balanced, but designed to stay tilted so you could drive up on it. It looked weird but worked great. I think this guy did a makeshift job of copying that design. Although his doesn't look like a tilt but by raising the front it would tilt. Makeshift job for sure but it worked for him.
    modify, adjust and improvise....a country boy can survive
Similar Threads
  1. Dump trailer to haul tractor?
    By El Wood in forum Trailers & Transportation
    Last Post: 07-31-2012, 11:09 AM
  2. trailer to haul hay
    By robert23239 in forum Trailers & Transportation
    Last Post: 05-08-2009, 12:50 AM
  3. What trailer to haul 2 machines on?
    By Botabill in forum Trailers & Transportation
    Last Post: 11-22-2008, 03:30 PM
  4. Trailer to haul RTV
    By RTVLady in forum Trailers & Transportation
    Last Post: 12-28-2004, 10:08 PM
  5. Trailer to haul RTV
    By RTVLady in forum ATVs & Utility Vehicles
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
