Page 11 of 22 FirstFirst ... 89101112131421 ... LastLast
Results 101 to 110 of 212
  1. #101
    Super Star Member
    Join Date
    Apr 2004
    Posts
    13,569
    SF Bay Area-Ca Olympia WA Salzburg Austria
    Cat D3, Deere 110 TLB, Kubota BX23 and L3800 Craftsman Mower, Deere 350C Dozer 50 assorted vehicles from 1905 to 2006
    Default Re: Rental Yards here now require 3/4 ton truck or better when towing.
    Quote Originally Posted by Rford View Post
    If a rental outfit, or anyone else, knows that somebody is getting themselves into a dangerous towing situation, I'd hope they'd prevent it. And if they don't, when they could, and some guy runs over me or my loved ones, I'm suing everyone involved. And that's only right.
    My point is the 3/4 ton of better truck really is a line in the sand when 1/2 ton trucks are made and sold with several times the rated towing capacity of the equipment I wanted to rent.
    If the yard was serious, they would evaluate each vehicle based on manufacturer's rating, load and hitch specifications...
    When I worked in Austria, the registration for every vehicle clearly states the maximum towing capacity in bold print... towing a trailer is as simple as comparing the registration of the tow vehicle with the equipment to be towed...
  2. #102
    Elite Member Depmandog's Avatar
    Join Date
    Nov 2010
    Posts
    2,598
    Buckner MO, LaPlata MO
    2005 Kubota L5030 GST; Farmall 706, 756, 806 & 1086
    Default
    A tad off topic, but it has been discussed in the thread...thought some of you might be interested.
    I bought my son a new F150 4x4 SuperCrew with the ecoboost 3.5 V6 last week. Didn't plan on buying new, but 2 year old trucks with 40k miles were about the same price as the heavily discounted new units - courtesy of Ford Truck month. That and Ford extended the powertrain warranty to 5 years / 100k ...it was a no brainer.
    We decided to get the ecoboost engine after tons of research. I have linked the first of 5 or 6 videos from Ford called the Ecoboost Torture test. Expressive to say the least!
    http://youtu.be/ttMD-n2D_18
    I will tell you...I am amazed...365 HP / 420 pounds of torque from a V6. Power off the line, turbos kick in at low RPM - you can feel them spooling at 1500 RPM. 21 mpg highway with a 36 gallon tank. That's some range.
    Too bad I won't get to drive it much!!
    Dean
  3. #103
    Super Member TomSeller's Avatar
    Join Date
    Jan 2013
    Posts
    8,694
    JD, Massey, Kubota, Case
    Default
    Sounds like it is Ford Tough. Impressive.
  4. #104
    Veteran Member sd455dan's Avatar
    Join Date
    Oct 2012
    Posts
    2,105
    North Idaho
    Rhino 554, JD550G dozer Gilson MTD riding mowers Ford 3000-Sold
    Quote Originally Posted by Depmandog View Post
    Episode 1 Ford F 150 EcoBoost Torture Test - YouTube
    Maybe we can get your input on the tires? I'm wondering what these half tons come with from the factory. If it's not to much trouble, Would you mind posting the specs including load range?? And the GCWR, your truck seems to fit the high powered Eco boost that is what everyone has been discussing. That does sound like a blast to drive-with that much power probably give a few old muscle cars fits 0-60 and with much better mileage.
  5. #105
    Join Date
    Nov 2010
    Posts
    2,598
    Default
    Quote Originally Posted by sd455dan View Post
    I sure will. My son is at college, but is planning on coming home tonight or tomorrow. I will get the specs and post here. Honestly, I am not sure if they put LT or P tires on This particular dealer orders all his trucks "models" spec'd with with the same options. For instance their ecoboost trucks have the 7,200 GVWR option, tow package (brake controller, trailer sway control and receiver) rear camera, rear sensors.
    Ours is a 3.55 with electronic locking rear differential. Will post the other specs later.
    Dean
  6. #106
    Join Date
    Oct 2012
    Posts
    2,105
    North Idaho
    Quote Originally Posted by jejeosborne View Post
    All trucks including 2500 series require a weight distribution hitch above a certain limit. Some 3/4 ton trucks have a 300 lb tongue/3000 lb limit without one. The 500/5000 limit is actually average to above average in 3/4 tons.
    Unfortunately many don't realize this. I see a lot of skid steers and mini excavators being hauled behind 3/4 ton trucks without a WD hitch and 99% of them are exceeding their hitch limits. You can purchase aftermarket hitches but that doesn't change what the manual states.
    Having the WD hitch spreads the tongue load across all the bolts holding the hitch on rather than just the rear bolts taking all the tension. Not to mention adding addition weight to your most important stopping axle, the front.
    You are correct, towing capacities between the 3/4 ton and 1/2 ton are similar. What you gain is cargo capacity.
    I noticed this on another threadRental Yards here now require 3/4 ton truck or better when towing.-ford-f-150-gvwr-jpg now check the listed tire inflation (35psi) someone correct me if I'm wrong , but shouldn't the pressure be closer to 80 psi If this truck is going to pull an 11,000 lbs.+ trailer, those air pressure #s look like passenger car inflation pressures?? I just want everyone to be safe especially towing at max weights... Now if i'm wrong on this assumption that all trucks that are going to tow 10,000+lbs. should have 10 ply rated, load range E tires. Please set me straight. I just don't want anyone to have an accident due to tire overloading
  7. #107
    Elite Member Dmace's Avatar
    Join Date
    Oct 2005
    Posts
    3,838
    Wakefield, NH
    Kioti CK20 HST
    Default
    Tire pressure and load ratings are more important when talking payload not tow capacity. When towing 11k lbs the tires may see 1100-1500 lbs of tongue weight. Hardly enough to require 10 ply tires.
    I will add though that the sticker clearly list P rated tires which is ridiculous. That truck should have LT tires.
    Derek
    Kioti CK20HST
    KL120 FEL // KB2365 BH // 60" JRW 3ph snowblower // 48" HD Boxblade
    Sims-Cab Depot heated cab
    Quote Originally Posted by DiamondPilot
    Now it's time for Ford and GM to step up
  8. #108
    Elite Member
    Join Date
    Oct 2003
    Posts
    3,628
    the Steernbos (Holland)
    Zetor 3011, Zetor 5718
    Quote Originally Posted by Bubbanewf View Post
    ITs like GEICO not insuring Mustangs years ago. Mustangs were black listed and they didnt care if you were a 70 year old lady and the mustang had a 4 cylinder engine. If it was a mustang, they would not insure it. Why? They told me it was because the type who bought them (teenagers) had too many wrecks and it was easier just to blacklist all Mustangs than argue who drives how.
    A VW Golf is very expensive to insure over here. Because the type of drivers you refer to: Wannabe macho kids wearing baseball caps the wrong way.
    When i discarded my Volvo 440 (small family car, predecessor of the S40 and V40) after my boss hit it with the 5th wheel trailer on the parking lot, and bought my first 850, i payd the same insurance despite the 850 being 400kg heavier. Assumably the typical driver of larger older Volvos doesnt get involved in damage that often... ?
  9. #109
    Join Date
    Oct 2005
    Posts
    1,704
    Southern Indiana
    Kubota/B7800
    Default
    I noticed this on another thread<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=310808"/> now check the listed tire inflation (35psi) someone correct me if I'm wrong , but shouldn't the pressure be closer to 80 psi If this truck is going to pull an 11,000 lbs.+ trailer, those air pressure #s look like passenger car inflation pressures?? I just want everyone to be safe especially towing at max weights... Now if i'm wrong on this assumption that all trucks that are going to tow 10,000+lbs. should have 10 ply rated, load range E tires. Please set me straight. I just don't want anyone to have an accident due to tire overloading
    Yes, that is my sticker. I agree, I would benefit from LT tires. They were an option with the HD package but it would have forced me into a 6.5' bed with the SCREW cab. These passenger tires to cover my axle ratings at max pressure. Here is my sidewall. These tires cover me up to my 11,300 towing capacity. When replacement time comes around, I will probably opt for P tires again for my needs.
    Attached Thumbnails Attached Thumbnails Rental Yards here now require 3/4 ton truck or better when towing.-image-1679054685-jpg
  10. #110
    Join Date
    Oct 2005
    Posts
    3,838
    Wakefield, NH
    Kioti CK20 HST
    Default
    So do you run those tires at 44 psi or the Ford recommended 35?
    Those tires are not gonna take your axle rating at 35 psi for long. Looks like Ford is asking for another Explorer/Firestone class action suit by cheaping out in important areas...
    Derek
    Kioti CK20HST
Similar Threads
  1. turning a 3/4 ton truck into a dump truck??
    By BWS in forum Attachments
    Last Post: 08-04-2016, 12:49 AM
  2. Towing with a chevy 1/2 ton
    By daveandlo in forum Trailers & Transportation
    Last Post: 01-30-2010, 11:50 AM
  3. Decided to go for broke--one ton flatbed truck for tractor towing
    By flusher in forum Trailers & Transportation
    Last Post: 08-06-2009, 03:27 PM
  4. Rental truck for towing trailer
    By TwinCreek in forum Trailers & Transportation
    Last Post: 09-26-2007, 08:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
