Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Super Member schmism's Avatar
    Join Date
    Jul 2006
    Posts
    5,108
    Peoria IL
    New holland TC(33)
    Default Re: Winch wiring
    extra battery, just used for winch duty.... kept in the shop on a trickle charger.... or your trolling motor battery.... or your RV battery.... or ......
    same idea as a jump box, just larger capacity.
    Steve - TC33D 4x4 FEL, dual rear remotes with toys
  2. #12
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Quote Originally Posted by schmism View Post
    That is what I do. I have a few old car battiers I use.
  3. #13
    Elite Member
    Join Date
    Jul 2006
    Posts
    4,409
    Northwest, WA
    If you want to do a run from your main battery, running ground thru the frame works fine.
    Used a Anderson powerpole 175 amp connector between truck and trailer.
    ::Sent from a standard desktop keyboard::
    My Photobucket
  4. #14
    Veteran Member CliffordK's Avatar
    Join Date
    Mar 2013
    Posts
    1,202
    Eugene, Oregon
    Toro D200, Ford 1715, International 884,
    Your choice of connections would depend a bit on how much you wish to use the winch with the trailer.
    I added a receiver to the front of my Blazer.
    Winch wiring-frontreceiver-jpg
    Made with a piece of channel iron, and a receiver tube.
    It is more securely connected to my winch than my winch is connected to my bumper or frame.
    Anyway, so all I do is insert a drop hitch.
    Pull up to the trailer and hook on.
    The advantage of the hitch is that I now have control of the trailer.
    And I have a great multi-purpose winch.
    I haven't used it with a tilt trailer though.
  5. #15
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    i put a bat on the trailer that is charged when hooke dup to the trailer plug. works great for a electric winch.. wireing is easy.. 90% of it is already there..
  6. #16
    Gold Member
    Join Date
    Jun 2010
    Posts
    251
    Oliver 1655
    I hooked mine up like Sound Guy. The battery operates a 12,000 winch & the hydraulic pump for the trailer tilt. I have the winch mounted on a 1/4" plate welded to a section of 2" x 1/4" wall square tubing which slides into a standard receiver hitch & have wired it with short lengths of #2 copper wire with welding lead connectors to make placing the winch into operation a snap. The battery on the trailer has matching cables attached. (The positive (+) is a female & the negative (-) is a male to help prevent it from being connected backwards. I also have a heavy set of battery cables which have a pair of the welding connectors on one end to allow me to use the winch anywhere I have a battery available.
    Some of the ways I use my winch: Skid logs with tractor, load vehicle on trailer, mounts on boom on loader & can pull up well pumps (The boom reaches 29' in the air), vehicle recovery, stretching fence, ...
  7. #17
    Join Date
    Mar 2010
    Posts
    2,109
    My warn winch (12000) has always worn the battery jumper box down before getting the load on the trailer. I use a 1000amp top post autozone battery with the harbor freight solar battery charger always hooked up. This is sometimes not enough. Out comes the 24 ft jumper cables to the two batteries under the diesels hood. This is exactly why commercial rigs run PTO or Hyd. winches.
  8. #18
    Gold Member
    Join Date
    Jun 2010
    Posts
    251
    Oliver 1655
    2458n - That is Weird! On a full charge, my 1000 CCA battery (has dual terminals) when not hooked up to a charging source will run the hydraulic pump to tilt my trailer, run the 12,000 lb Badland winch from Harbor Freight to load a full sized van, lower the trailer to transport position, Re-tilt & lower at delivery point, run the winch for a controlled unload (though most of the time I just let the vehicle roll), & still have battery to spare. Have you done a load test on your battery to check for a bad cell?
  9. #19
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default
    Quote Originally Posted by Oliver1655 View Post
    Same here. My winch is only 4500# but I have loaded 3 cars in a 2 hour period using my jump box with no sign of slowing down.
    Chris
Similar Threads
  1. Wiring electric winch plug for Log arch winch
    By Piston in forum Customization
    Last Post: 02-26-2011, 12:14 PM
  2. Boat winch wiring
    By Grand_Pooba in forum Trailers & Transportation
    Last Post: 07-18-2010, 01:17 AM
  3. Winch Wiring for Kubota 3130
    By Rory_Rhodes in forum Attachments
    Last Post: 01-01-2005, 07:07 PM
  4. RTV Winch installation & wireless winch?
    By Slippy in forum ATVs & Utility Vehicles
    Last Post: 07-23-2004, 02:28 PM
  5. Winch wiring question (12V)
    By Gary_in_Indiana in forum Related Topics
    Last Post: 01-03-2003, 04:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
