Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
  1. #21
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Default
    Quote Originally Posted by Bday View Post
    Thanks Josh, I have been pricing class 5 s. What I have found so far has been $400 and up. I'll keep looking if I go that route. The trailer tongue weight won't be anywhere near the 500 lb. rating according to what the dealer told me. The sticker on the truck hitch just has 10,000 lb rating and 500 tongue. No other info.
    If you're bumper pulling a 12k trailer and your tongue weight is much under 1.2k, you've got a problem, unless you know something I don't.
    I would suggest looking into your owner's manual or calling the dealer, because those numbers are possibly incomplete, since they don't mention with or without WD. But rated tongue weight is basically always 10% of rated trailer weight, so 10k / 500 lbs is very unusual.
    Sent from my DROID RAZR HD using TractorByNet
  2. #22
    Silver Member Bday's Avatar
    Join Date
    Dec 2012
    Posts
    203
    Lucerne, IN
    53' Allis WD, 54' Allis WD 45, 52' allis CA, Farmall 560, 656 , 47' Deere model A , 38' Deere model A
    Default Re: Trailer hitch question?
    Quote Originally Posted by Xfaxman View Post
    The first thing I would do is find a 2-5/16" ball rated for 14K, and the correct height 2" square ball mount rated for 14K.
    No use beefing the hitch if you cant trust the mount and ball.
    That's exactly what the dealer told me. Upgrade to the rated ball and mount. He told me not to spend the money on a heavier hitch. With that info, I thought adding some more meat to the hitch itself might help.
  3. #23
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,733
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Point taken on the liability issues. The trailer is only used here on my farm. Just hauling tractors and equipment from one farm to the other. The trailer wasn't purchased for long hauls with my truck. The trailer dealer I bought it from said my hitch would be fine I just needed to upgrade to a heavier receiver for a 2 1/2" ball. Hence the question for adding some structural strength to the hitch for the added weight.
    If I was hauling long distances all the time and not just short trips a few times a year then I could see spending the money for a new hitch. Gross trailer weight shouldn't be much over 12,000 with what I haul. Thanks for all the competent posts! The trailer was bought at Tc trailers out of Frankfort, In. Call them up and see what they recommend for a hitch! That's what threw me on the hitch requirements.
    Some salesmen will say anything to make a sale. A 2 1/2 ball mount is class 5.
    How much does the empty trailer weigh?
    My 14K metal deck gooseneck weighs 5150 pounds, leaving 8850 pounds to total 14K gross trailer weight (GTW).
    From Reese hitch.
    Class IV
    Class IV hitches are weight carrying (WC) and weight distributing (WD) hitches depending on the vehicle and hitch specifications.
    Not all Class IV hitches are rated to be both. See the specific hitch for that information.
    Class IV hitches used as weight carrying are rated up to 10,000 lbs. gross trailer weight (GTW) with a maximum trailer tongue weight (TW) of 1000 lbs.
    Class IV hitches used for weight distributing are rated up to 14,000 lbs. gross trailer weight (GTW) with a maximum trailer tongue weight (TW) of 1400 lbs.
    A Class IV hitch usually has a 2" square receiver opening.
    A higher class drawbar does not increase the towing capacity of the hitch. To use this class of hitch for weight distribution requires a weight distribution system.
    Class IV hitches attach to the vehicle frame only.
    Class V
    Class V hitches are weight carrying (WC) and weight distributing (WD) hitches depending on the vehicle and hitch specifications.
    Class V hitches used as weight carrying are rated up to 12,000 lbs. gross trailer weight (GTW) with a maximum trailer tongue weight (TW) of 1200 lbs.
    Class V hitches used for weight distributing are rated up to 17,000 lbs. gross trailer weight (GTW) with a maximum trailer tongue weight (TW) of 1700 lbs.
    Your ball mount and hitch ball need to both be rated for Class V to safely tow these weight loads. To use this class of hitch for weight distribution requires a weight distribution system.
    A Class V hitch has a 2-1/2" square receiver opening.
    Class V hitches attach to the vehicle frame only.
  4. #24
    Super Member s219's Avatar
    Join Date
    Dec 2011
    Posts
    6,568
    Virginia USA
    Kubota L3200 Deere X380 Kubota RTV-X
    Welding is just your ticket in the door, but to do it right you need to be able to design/analyze the mods, and to me that means having engineering skills and design tools. Or at least have a copy of an existing hitch rated for the loads you're after, which you can reverse engineer. I wouldn't go into this just based on welding skills alone though. Beefing up an existing design can often mean you overlook important details or weak points.
  5. #25
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,206
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    How does $238 for a hitch rated at 1800# Tongue weight and 18000# Maximum gross trailer weigh sound?
    Put the $150 you were going to spend in metal and the $100 that you can probbaly sell your current hitch for and you can pay yourself $18 to install the hitch while saving the time and consumables that you would have spent to beef up your current hitch.
    See: Trailer Hitch for 2008 Dodge Ram Pickup - Curt C15604
    Aaron Z
    A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
    Robert Heinlein, Time Enough for Love
  6. #26
    Join Date
    Dec 2012
    Posts
    203
    Lucerne, IN
    Quote Originally Posted by aczlan View Post
    Aaron Z
    Wow can't argue with the prices. Do you know anything about this brand? Thanks Aaron
  7. #27
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,206
    Curt is a fairly big name in trailer hitches. IIRC, they are made in the US.
    Aaron Z
  8. #28
    Join Date
    Dec 2011
    Posts
    6,568
    Virginia USA
    Several of the big names in hitches are even made in the same factory, so often times you'll see the same hitch under a couple brands (perhaps even OEM) and if one is good they all are. I have installed a couple Curts over the years and they are good.
  9. #29
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,019
    Port Orchard, WA.
    John Deere, 4200
    Welding is the easy part, the engineering is the tricky part. Do you have any pictures of the hitch you want to beef up?
    I've built several hitches, and a couple gooseneck adapters to convert bumper pull trailers to gooseneck.
    I've also been involved in law suits for the company I worked for. Our legal system considers you an expert when you have 20 or more years in your field.
    Here are some pictures of a Super Hitch I built for a friend. He has a 10-feet long camper that hangs over the back bumper, but he still needs to pull his horse trailer. I built this hitch about 10-years ago, still going strong.
    First picture is of a factory hitch, with a longer extension. The last picture is of the completed hitch, before he installed the chains.
    Attached Thumbnails Attached Thumbnails Trailer hitch question?-880-00-jpg   Trailer hitch question?-front-jpg   Trailer hitch question?-my-super-hitch-jpeg
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  10. #30
    Join Date
    Dec 2012
    Posts
    203
    Lucerne, IN
    Quote Originally Posted by Shield Arc View Post
    Hey looks great shield arc! Amazing how easy it is to fab something up isn't it. Is that 3/8s for the brackets? What's the wall thickness on the tubing? What's the weight rating on it? Are you worried about any liability issues with your work?
Similar Threads
  1. Hitch question, trailer tongue.
    By QRTRHRS in forum ATVs & Utility Vehicles
    Last Post: 04-13-2012, 10:06 PM
  2. Question On FEL Step Bumper Trailer Hitch
    By Keuka in forum Attachments
    Last Post: 10-21-2010, 02:00 PM
  3. goose neck trailer hitch question
    By leveller in forum Trailers & Transportation
    Last Post: 06-25-2010, 06:11 PM
  4. Combo Quick Hitch Adapter and Trailer Hitch
    By Runner in forum Build-It Yourself
    Last Post: 04-29-2008, 06:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
