Results 1 to 7 of 7
  1. #1
    Silver Member stratton's Avatar
    Join Date
    Nov 2010
    Posts
    150
    east of rochester ny
    kubota b2320
    Default First time towning the Kubota
    First time towning the Kubota-imag0701-jpg
    I was a little worried about towing the tractor behind my Tacoma, But it did ok. almost 5000lbs there. Good thing for trailer brakes.
  2. #2
    Super Member s219's Avatar
    Join Date
    Dec 2011
    Posts
    6,650
    Virginia USA
    Kubota L3200 Deere X380 Kubota RTV-X
    Default Re: First time towning the Kubota
    Looks like a nice trailer there, so it's good to see someone doing it right with proper equipment.
    I tow my B2920 on a 7x16 tandem landscape trailer with brakes, using an Acura MDX (5000# tow rating), and it does well. Won't win any drag races, but the overall stability and braking are extremely good. It tows real nice and I've never had a worry once I got over my initial concerns.
    I see many guys in 3/4 ton pickups hauling unbraked trailers that look like they are about to self destruct, so to me it's not the size of the tow vehicle that counts, it's the safety and condition of the whole package.
  3. #3
    Join Date
    Nov 2010
    Posts
    150
    kubota b2320
    I wouldn't dare tow that much with out brakes. The truck is rated up to 6500lbs with the tow package. Which sounds like a lot for a 6 cylinder. I only towed it about 5 miles so I didn't notice how much gas it guzzled.
  4. #4
    Gold Member Hay Dude's Avatar
    Join Date
    Aug 2012
    Posts
    326
    Delaware Valley
    McCormick, JCB, Kubota
    One thing to keep in mind is if you get a DOT audit. I was back hauling a tractor for someone in the Midwest. When I was going through PA on the way home to DE, I got stopped at a checkpoint. I have a class a with air brakes and hazmat endorsements. The cop told me that they were now fining anyone towing a tractor with more than a "small" fuel tank that didn't have hazmat insurance coverage. I wasn't quite sure what he was talking about. He went on to say the state is now considering a rolled over trailer with a piece of equipment on it that leaks diesel fuel all over the road a hazmat situation. "You need to carry the proper insurance and a hazmat spill kit".
    Luckily I already had both. This was only a 70hp tractor with about 5 gallons of diesel in it. I would suggest you check your insurance coverage and buy a spill kit for your rig. I have way over a million miles logged of hauling with an apportioned license and that's the first time I have heard that. Called my DOT auditor when I got home and he said it was true.
    M series Kubota MFWD tractors. JCB Fastrac New Holland PT & Pottinger front mount discbines. NH round hay balers. GM, Ford, IH, trucks.
    Hay Farmer & shipper. We grow & ship about 1,500 4x5 round bales/yr.
  5. #5
    Gold Member
    Join Date
    Oct 2010
    Posts
    346
    Central Texas
    JD 3520, JD X584
    Quote Originally Posted by stratton View Post
    Hi Stratton,
    Good to see Tacoma's and tractors!
    I have a new 2013 Tacoma v6 PreRunner with the tow package and am working on configuring a trailer for my JD 3520. Tractor weighs approx. 3000lbs.
    Questions:
    - Are you using a weight distribution hitch? My understanding is that a weight distribution hitch is needed (actually, required per the Tacoma manual) to tow the max 6500lbs.
    - What width and length is your trailer?
    Thanks much,
    - Spindifferent
  6. #6
    Super Member newbury's Avatar
    Join Date
    Jan 2009
    Posts
    9,123
    From Vt, in Va, retiring to MS
    Kubota's - B7610, M4700
    Quote Originally Posted by Hay Dude View Post
    <snip>The cop told me <snip>the state is now considering a rolled over trailer with a piece of equipment on it that leaks diesel fuel all over the road a hazmat situation. <snip>
    What about a rolled over 350 w/ 38 gallons? Hazmat for everything bigger than a 5 gallon tank?
    My rides - '95 Kubota M4700 w/ PEC, LA1001 FEL :'07 B7610, LA352 FEL, Bush Hog SBX 48 box blade, '09 Woods BH70-X w/ 16" bucket and thumb, 3pt pallet forks, Dale Phillips PHD, Jinma 8" chipper, 2 Piranha's, Winco 12KW PTO generator, Howse plow, 5' KK tiller, 5' Big Bee cutter, with a 2002 7.3L Ford F350 CC DRW 4x4 and '07 18' Hudson HSE Deluxe trailer - 5 Ton to haul it all
    My saws - 12" B&D 40 volt,JD CS 62, efco 3500, Stihls - 021, 660 w/woods mod, 660 w/ DP muffler, 088, Woodmizer LT10
  7. #7
    Join Date
    Nov 2010
    Posts
    150
    kubota b2320
    Hay Dude I didnt hear of that but I will look into it. What does a spill kit consist of? Cat litter?
    Spindifferent, The trailer is 18' long and I think its 6' wide. The hitch came from the factory so i am not sure exactly which one it is. But they told me it has a 6500lb limit. Since it also came with a harness for the trailer brakes it was easy to add the brake controller.
Similar Threads
  1. $$ Kubota Seat time
    By Agrantina in forum Kubota Owning/Operating
    Last Post: 10-11-2010, 08:02 AM
  2. First time Kubota owner!
    By Weldorbill in forum Kubota Owning/Operating
    Last Post: 11-18-2007, 08:09 AM
  3. Need advice on towning my TC 40A
    By Todd_C in forum Trailers & Transportation
    Last Post: 07-31-2007, 02:33 PM
  4. Kubota Hour Meter-Real Time or PTO Time
    By GuyL in forum Kubota Owning/Operating
    Last Post: 07-18-2006, 11:12 PM
  5. Crunch Time between HH and Kubota
    By bmkr94 in forum Buying/Pricing/Comparisons
    Last Post: 09-19-2005, 07:59 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
