Page 16 of 17 FirstFirst ... 61314151617 LastLast
Results 151 to 160 of 170
  1. #151
    Veteran Member fordmantpw's Avatar
    Join Date
    Mar 2013
    Posts
    2,003
    Central MO
    John Deere 2720
    Default Re: 2014 Chevy/GMC specs
    Quote Originally Posted by sd455dan View Post
    I stand by my statement about (IN THE PAST) ohv engines vs. ohc.
    In many cases ohv are lower revving they also in many cases produce more total torque than total horsepower. I know of very few normally aspirated ohc engines that can make that claim...
    Ohc engines generally will rev higher producing more peak horsepower, but do not generally produce as much torque at low rpms.
    A good example of these normally aspirated ohv engines are my favorite Pontiacs.
    Like some of the versions Butler performance builds- the basic 455 cu producing 580 hp 625 ft. lbs. also average torque far exceeds average horsepower.
    Many ohv engines produced more average torque than horsepower.
    If ohc head designs produce as much or more low end torque, you would think they would be in use on more than half the diesel tractor engines and over the road diesels.. I believe its all about low end torque...
    I maintain that in general - in the past normally aspirated ohv engines produce more low end torque than ohc engines
    The Ford 5.4 L (OHC) has always had more torque (especially at low-end) than the 5.3 L (OHV) engines. Ask those that have towed with them, and they will tell you the 5.4L tows much better than the 5.3L. Heck the 5.4L had almost as much torque as the 6.0L in the GM's...lacking what, 10 ft-lbs? It's all in the tuning of the engine, not the OHC vs. OHV debate.
  2. #152
    Veteran Member deerefan's Avatar
    Join Date
    Aug 2005
    Posts
    1,698
    louisiana
    1952 8N, 2005 JD 5103
    Default
    Quote Originally Posted by fordmantpw
    I cant speak for the 5.4. I have a 97 F150 with the 4.6 (4x4) that is gutless when towing. I am not a big fan of the mod motors. PITA to work on. The 5.3 tows a lot better with the new 6 speed auto. I only tow occasionally. If towing regularly, I would have a diesel.
  3. #153
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Quote Originally Posted by Peacock View Post
    Because they say. I guess that is reliable. Plus it looks different to my eyes.
    It is considered a gen 5 engine right?
    Quote Originally Posted by fordmantpw View Post
    The 5.4 is a long stroke motor (4.165). That helps with torque. Most of the Fords were geared to high.
    Quote Originally Posted by deerefan View Post
    What gears and tires on the 4.6 F-150. For the most part you don't have to do much work to a mod.
  4. #154
    Join Date
    Aug 2005
    Posts
    1,698
    louisiana
    Default
    Quote Originally Posted by 94BULLITT
    3.55 gears, factory 265/75/17 tires. Auto trans. Good run around truck, great off road plenty of clearance, just not a strong tower.
  5. #155
    Join Date
    Mar 2013
    Posts
    2,003
    Central MO
    John Deere 2720
    The 4.6 wasn't known as a good towing motor, but was better than the 4.8 in the Chevy. The 5.4 on the other hand, was a different story. It was a great towing engine. I towed a travel trailer with it (with the old 4 speed tranny, not the newer 6 speed) and it towed great.
  6. #156
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    That is way too big of tires on it. I know a guy that has that same combo, it is gear like a airplane. With those tires it should have had 4.10's
  7. #157
    Join Date
    Aug 2005
    Posts
    1,698
    louisiana
    Default
    It is what it came with new in 97. Bad engineering?
  8. #158
    Join Date
    Jan 2011
    Posts
    573
    Richmond, IN
    Kubota MX5100
    Quote Originally Posted by 94BULLITT View Post
    Yes.
    And actually what I have now found is that they share 'a few parts like rocker arms'....
    Kubota MX5100
    '95 Ram 2500 CTD
    Stihl MS441 ported
    Stihl MS280 ported
  9. #159
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Default
    No just stupid salesmen ordering them like that.
  10. #160
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Default
    Yes.
    I found they share a few things, I think it resembles the LS motors.
    http://www.gmhightechperformance.com...k/viewall.html
Similar Threads
  1. Anyone else holding out for new 2013 Chevy/GMC truck?
    By Topkicker in forum Trailers & Transportation
    Last Post: 12-30-2011, 03:17 PM
  2. 4500/5500 series Gmc/Chevy
    By Robbie Hegwood in forum Trailers & Transportation
    Last Post: 02-05-2007, 06:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
