Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Super Star Member
    Join Date
    Apr 2004
    Posts
    13,569
    SF Bay Area-Ca Olympia WA Salzburg Austria
    Cat D3, Deere 110 TLB, Kubota BX23 and L3800 Craftsman Mower, Deere 350C Dozer 50 assorted vehicles from 1905 to 2006
    Default Re: Trailer Length for JD 110 TLB ?
    Quote Originally Posted by dondc View Post
    The only way IMO for anyone using an 18ft trailer to haul a backhoe should back the TLB on to the trailer to get the correct weight distruibution. The FEL bucket can slightly overhang the rear deck of the trailer if properly chained on.
    If the axles are set back and the trailer is made for a 110 the weight distribution should be spot-on.
    Looks like the PJ 6" channel framed equipment trailers are standard with two 7k axles for 14k GVW
    Heres a picture of the model I have...
    http://gofast.sunsationtech.com/PJ618DF/pix%20035.jpg
    The difference between 18' and 20' is about 150 lbs more weight from the brochure...
    PJ Trailers - 6" Channel Equipment (CC)
  2. #12
    Join Date
    Aug 2005
    Posts
    243
    northeast tennessee
    Bobcat B300
    if you generally will have room to turn around the trailer I would go as long as you feel comfortable with. I always find a reason to carry an attachment or 2 and the room is nice. with that in mind a 14,000# trailer makes sense as well. I use a 22' trailer with a dovetail and back my backhoe onto the trailer. this way i can carry an attachment on either side of the backhoe boom.
  3. #13
    Gold Member KubotaToy's Avatar
    Join Date
    Nov 2011
    Posts
    413
    SE Tennessee
    Kubota B2710HSD (hers) and L45 (mine), RTV1100 (hers), Yanmar VIO80
    I have an L45 which is similar to a 110. I haul it around on a 14k 20ft (5ft dovetail that levels so I really have 25ft to work with) and would like to have another 5ft if I had it to do over.
  4. #14
    Elite Member CurlyDave's Avatar
    Join Date
    Dec 2005
    Posts
    4,480
    Grants Pass, OR
    JD TLB 110
    I am convinced. It will be the 14k trailer.
    Now for a second question. Tilt bed or ramps?
    The ones I looked at had ramps, but did not have jackstands under the top of the ramps, which I believe can lead to a dangerous situation during loading/unloading. I think a tilt bed would be more safe, but I need advice.
    Thanks,
    Dave
    40 Acres on a hill - fantastic view. JD 110 TLB, 4-n-1, 12" bucket, 18" bucket, Addington thumb, rock bucket (doubles as root grapple)
    Not only do we not understand the universe, if someone explained it to us, we would not know what he was talking about.
    Isaac Asimov
  5. #15
    Super Member AKfish's Avatar
    Join Date
    Oct 2004
    Posts
    5,402
    Alaska
    JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
    Quote Originally Posted by CurlyDave View Post
    Thanks,
    Dave
    Dave,
    I've had both types. I really liked the convenience of the tilt bed but ice and snow in Alaska made for some problems with locking/unlocking the tilt mechanism and ensuring that it would stay locked after breaking it free! As well, it was noisy with the bed clanking and clunking on rough roads or any manner of bump.
    I have since sold that trailer and replaced it with a bumper-pull 14k with slide in ramps. Don't go with the slide in ramps! Your back will thank you.. It does not have the load legs at the rear of the trailer, either.
    I wish that it did have them. Not for reasons of safety, necessarily. I've never been in a situation either loading or unloading that I've believed that the legs would have made any difference or not. I believe that they would be helpful to relieve some of the trailer "jump" - that rocking back and forth - especially when you first get loaded that can be especially damaging to the Park pawl in the automatic transmission of your truck.
    I went to a goose neck with fold-over ramps and a flat-deck over the axles. That makes for much easier loading and unloading of materials and equipment using forks, etc.
    I realize that you're considering a bumper pull... but, handling, maneuverability and safety is much better with a GN - IMO.
    That said, if you're only planning to tow infrequently and/or for short distances a 14k bumper pull is more than enough trailer for your 110.
    AKfish
    "Most people want to live on top of the mountain, but all the happiness and growth occurs while you're climbing it."
  6. #16
    Gold Member
    Join Date
    Nov 2009
    Posts
    338
    Grimes County, Texas
    Kubota GL 3940
    Dave, It's easy enough to add the rear stabilizing jacks to the trailer. I think it was around $100 when I bought my PJ. Just ask for them. If they are not on the trailer you want, they can be bought separately and the base welded on easily by any welder or welding shop.
    Kubota GL 3940, FEL w/ssqa, third function valve, grapple, 6' Landpride cutter, 6' landscape rake, 6' box blade, post hole auger
    "Knowledge is knowing the street is one way. Wisdom is still looking both ways before crossing"
  7. #17
    Join Date
    Nov 2008
    Posts
    74
    Kerrville, TX
    2006 Kubota L39 TLB, Bobcat S160 Skid Steer
    I have a kubota L39 which is a little lighter than the JD 110 and I trailer it on a Top Hat bumper pull 18', 12K with slide-in ramps. I pull with a GMC 2500HD Duramax w/Allison 6 speed. Here's a few tips I have learned over the last few years.
    > Load the TLB with the backhoe at the front of the trailer for the best weight distribution.
    > As you back the 110 up onto the ramps the rear of the trailer will go down and the truck rear will raise up! You absolutely need some kind of stablizing jacks to minimize the rear drop when loading/unloading. (I put adjustable jack stands on each side of the rear of the trailer and that helps a lot).
    > Grade 70 transport chains w/ratchet binders - NO STRAPS!
    > It takes quite a few steps to load that tractor on the trailer. When your finished - check everything AGAIN!
    > Remember to "cross" your safety chains.
    > Test your brakes as soon as you start moving - no surprises!!
    > Spare tire for trailer, jack and lug wrench
    > After towing a few miles - pull over and check everything again. Carefully feel your hubs to make sure you don't have a bearing going bad or a dragging brake.
    I'm sure others can offer lots more advice. One more thing--- drivers will absolutely pull out in front of you just to see if you can really stop that much weight.
  8. #18
    Join Date
    Jan 2006
    Posts
    963
    West Central Idaho
    Kubota L5740HSTC3; B3000HSDCC
    Dave,
    This is a GN, but it is a 14k, 20', and the tractor load on it in the photo is 21 OAL.
    Attached Thumbnails Attached Thumbnails Trailer Length for JD 110 TLB ?-2013-04-17-12-56-a
  9. #19
    Join Date
    Oct 2004
    Posts
    5,402
    Alaska
    Quote Originally Posted by Jim Miller View Post
    Very good info. And, if there's something that really bears repeating it's: "One more thing--- drivers will absolutely pull out in front of you just to see if you can really stop that much weight." REALLY! However, I never believed that other driver's "intentionally" pulled that kind of stunt - I figured that they had no clue! Just plain ignorant... Most of 'em have never pulled or towed or managed any kind of load since they hauled their brother, sister or neighbor kid in their Red Flyer wagon! (Of course, nobody has a Red Flyer anymore, either!) So, they're doubly clueless...
    AKfish
    And I-5 around Portland and Seattle -- it's amazing that there aren't ambulances and medical staff posted every 15 miles or so on 24/7 standby along the freeway. Scary drivers....
  10. #20
    Super Star Member two_bit_score's Avatar
    Join Date
    Dec 2008
    Posts
    10,320
    Texas - from the brush and pear to the piney woods
    John Deere 110 TLB
    Quote Originally Posted by AKfish View Post
    AKfish
    Absolutely true. That's some of the scariest traffic I've ever seen.
Similar Threads
  1. Trailer length for 110 TLB
    By TLM in forum John Deere Owning/Operating
    Last Post: 06-05-2008, 05:49 PM
  2. Bx1500 and Trailer Length: Recommend Trailer Makes
    By AKFord in forum Trailers & Transportation
    Last Post: 05-07-2005, 09:47 PM
  3. Bx1500 and Trailer Length: Recommend Trailer Makes
    By AKFord in forum Kubota Owning/Operating
  4. Trailer Length For L48 TLB?
    By Ursushorribilus in forum Trailers & Transportation
    Last Post: 11-02-2004, 09:26 PM
  5. Trailer Length For L48 TLB?
    By Ursushorribilus in forum Kubota Owning/Operating
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
