Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
  1. #1
    Gold Member
    Join Date
    Sep 2004
    Posts
    291
    Default Ford 2000 On Trailer
    Would a 7K car hauler be adequate to move a Ford 2000 (3 cyl) with loader about 100 miles?
    My friend just hauled an MF 50 over 2,000 miles on the trailer in question with no problems, but there was no loader involved.
    Now he is thinking about the Ford with loader on the same rig and 100 mile trip.
  2. #2
    Veteran Member sd455dan's Avatar
    Join Date
    Oct 2012
    Posts
    2,105
    North Idaho
    Rhino 554, JD550G dozer Gilson MTD riding mowers Ford 3000-Sold
    Default Re: Ford 2000 On Trailer
    Quote Originally Posted by Harold_J View Post
    Well I believe the 2000 weighs in under 4000# add the loader maybe 1500# (full framed 730) and that leaves the tires if calcium chloride loaded 800# = aprox, 6300#
    Now if the tires aren't loaded- use the lower possible weight of the 2000 @3615# =4800# at a minimum I think if the payload rating of the trailer is a true 7000# should be OK...
    Attached Thumbnails Attached Thumbnails Ford 2000 On Trailer-ford-2000-specs-001-jpg
  3. #3
    Elite Member GManBart's Avatar
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Massey Ferguson 241, Case 580 Super M Series 2, Cat D3B
    The minimum weight for that Ford is 3,770 (call it 3,800 with fluids), the loader weighs 1200-1500lbs, and then you have the weight of the trailer. 7K trailers weigh at the very least 1,500lbs (open center), with many more like 2,000lbs. At the very least, the trailer will be maxed out....it just depends. Does the tractor have a canopy, loaded tires, etc? What does the trailer actually weigh?
  4. #4
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default
    I think its too much for it. A 7K trailer usually has a payload of 5000# to 5500#
    Chris
  5. #5
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    9,534
    Lincoln County, NC need new avatar!
    Just a Scag
    Quote Originally Posted by Diamondpilot View Post
    Chris
    I wouldn't put it on my 7K trailer. And I've hauled 5K a LOT and 5.5K more than a couple times. 5500lb doesn't look pretty on two 3500lb axles.
    Spring is the season of optimism.
  6. #6
    Join Date
    Oct 2012
    Posts
    2,105
    North Idaho
    the data plate on that trailer would help decide whether or not it can haul that 2000 Ford. I found my original 1968 sales flyer for 2-3000 tractors shipped weight is 3615 (3300 was low) the 3000 is 3790...Ford 2000 On Trailer-ford-2000-specs-001-jpg I believe that is with all fluids except diesel and loading of tires If they are loaded ? The #s appear to be to close without the payload rating of the trailer, and whether those tires are loaded....
  7. #7
    Platinum Member tessiers's Avatar
    Join Date
    Sep 2007
    Posts
    728
    Central Maine
    05' JD 790 - 53' Ford NAA - 70' Massey Fergusen 135 diesel - 67' John Deere 3020 deisel - 77' John Deere 2130 - 1950 John Deere MC
    I'd do it all open road, no problem. I have done way more damage to trailers right on the farm than on the road. Its the cutting and jigging that is hardest on trailers, racks the frames and puts side stress on the hubs and tires. Straight running on hot top is about as easy as it gets. Check the bearings, grease and lube everything and go for it.
    check us out at www.tessiersfarm.com
  8. #8
    Bronze Member AndyL52's Avatar
    Join Date
    Oct 2012
    Posts
    78
    Innis, LA.
    John Deere
    I wouldn't think twice about it. I'd hookup and hit the road. We have a car hauler trailer that we haul equipment with implement with no problem.
  9. #9
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Quote Originally Posted by tessiers View Post
    It's not about damaging the trailer. Just because running down the road won't hurt the trailer doesn't make it necessarily safe.
  10. #10
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,712
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    if the tires are unloaded and it's not a huge loader.. it's probably ok.
    I can tell you I've for sure done it. but can also tell you that I got a bigger truck and trailer so that I don't have to do it anymore either.
    i have an 850 with superior utility laoder on it and loaded 13.6-28 tires and a counterweight that probably weighs more than that 3 cyl and laoder.. and I've moved it on the trailer.. and only did so because i had a 1 ton pulling it... and knowing it was abusing the trailer too.. and it was a short 8m trip.. no way I'd do it on 100m
Similar Threads
  1. Oil & Fuel New owner of 1952 Ford 8N and 1968 Ford 2000 (gasser) needs some service suggestions
    By tmac196 in forum New Holland Owning/Operating
    Last Post: 02-25-2013, 12:29 PM
  2. what size trailer for 2000-2500lb.load?
    By 2001 JD4110 in forum Trailers & Transportation
    Last Post: 04-24-2012, 09:19 PM
  3. 3-Point Hitch Ford 2000
    By Mtcrash77 in forum New Holland Owning/Operating
    Last Post: 08-23-2011, 03:59 PM
  4. 63 Ford 2000
    By john15nlt in forum Hydraulics
    Last Post: 04-24-2010, 04:00 PM
  5. 3-Point Hitch Yanmar 2000 trailer hitch
    By technogeek in forum Yanmar
    Last Post: 05-02-2006, 08:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
