Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Super Member schmism's Avatar
    Join Date
    Jul 2006
    Posts
    5,113
    Peoria IL
    New holland TC(33)
    Default Paint the trailer
    Ive got my $500 livestock trailer to paint.
    I was innitally thinking of rolling on some rustoleum. Then i thought i might have Maco spray it after i prep it. But the I thought why not practice spraying rustoleum. I have plenty of other projects that could do with rustoleum paint jobs so....
    Internets say reduce it with automotive enamal reducer. 8-4-1 8 paint 4 reducer 1 hardner.
    At that point do you spray it with a regular 1.4mm HVLP gun? or should i go for a 2.2 "primer" gun and shoot something like 3-1.
    looking for feedback from people who have actually done this and what they used specifically.
    Steve - TC33D 4x4 FEL, dual rear remotes with toys
  2. #2
    Super Member George2615's Avatar
    Join Date
    Feb 2005
    Posts
    8,119
    Central Square, NY
    LS XR3037HC
    Default Re: Paint the trailer
    I sprayed Rustoleum paint on a new one piece floor pan I installed in a Chevelle convertible last year. I used a cheapy Harbor Freight HVLP gun, compressor air pressure set about 40#, (drops to about 30-35 pulling the trigger), 1.4mm, I thinned the paint roughly 2 to 1, (2 parts paint to 1 part mineral spirits). I did not use hardener just a day with a box fan blowing on it to dry. Rustoleum red for the top, when dry I put the car on the lift and sprayed rustoleum black underneath. It should work the same on your trailer. I've sprayed rustoleum on many projects, just happened to have a pic of this one. I did my car trailer in black using this mixture also but brushed it on rather than spraying.
    Attached Thumbnails Attached Thumbnails Paint the trailer-5-jpg
  3. #3
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default
    I have spayed trailers with it just thinning using paint thinner/mineral spirits.
    Set the gun to the specs for the compressor and go.
    You ain't painting a piano here......
    Chris
  4. #4
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,712
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    i'd get a harbor freight 20$ gun.. some TSC paint.. some naptha or mineral spirits ( based on paint recs ).. and then some quick cure hardner nason , if you aren't sensitive to it. and let her rip.
  5. #5
    Join Date
    Jul 2006
    Posts
    5,113
    Peoria IL
    New holland TC(33)
    word has it acetone works better than just reg mineral spirits without going to automotive enamal reducers.
    Dont suppose anyone has used a #4 ford viscosity cup?
    zahn #2 Ford #4 Viscosity Charts
    Ive done this before, but just kinda guessed at things, usually small to medium parts. For me the difficulty was in trying to reliably thin my paint. Some times it would go well... other times just awufull. So i guess they use the ford cup to remedy this especially when working with something generic like Rustoleum. Most of this was as a "kid" before i understood there was a relation ship between the type of gun (nozzle size), pressure, viscosity.
    Im going to try 30-40 sec in a #4 ford through a 1.8mm "primer" gun.
    ill update with some pics etc when i get to that point.
  6. #6
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    I sprayed a car trailer with rustoleum. It turned out good and still looks good after a couple of years. I think I used a suction gun on it. I can't remember how much I thinned it.
  7. #7
    Veteran Member varmint's Avatar
    Join Date
    Mar 2003
    Posts
    2,401
    Northern Maryland
    Kubota B8200, then a Kubota L3130 HST, now a Kubota L3400 HST
    Schmism got it with suggesting using acetone to thin the Rustoleum for spraying. I am getting ready to spray my trailer gate/ramp, and sure enough, right on the can of Rustoleum it says to use acetone. I guess it flashes off so fast that it helps with spraying. Never used hardner.
  8. #8
    Join Date
    Mar 2002
    Posts
    52,712
    Central florida
    i've seen some that use hexane for a reducer.
    i was a lil hesitant at first.. but let me say.. that nason synthetic enamil was touch safe in 15m using hexane thinner and quick cure hardner!
  9. #9
    Platinum Member Notforhire's Avatar
    Join Date
    Nov 2011
    Posts
    853
    Southwestern Virginia
    JD 5055E
    Quote Originally Posted by varmint View Post
    I just finished this trailer build, and used Rustoleum w/acetone. I wouldn't paint my car with it, but I like it for trailers. Touch up with a rattle can. What could be better?
    Paint the trailer-new-14-ft-trailer-002-a
    Bill
  10. #10
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Default
    Here is my rustoleum paint job. It has been on there over a year and a half. I still need to get the lights and winch on it and buy a tool box.
    I guess I thinned it with acetone if that is what the can says to use. I did use the rusty metal primer.
Similar Threads
  1. What kind of paint for my trailer?
    By Frank R in forum Build-It Yourself
    Last Post: 12-13-2012, 11:09 AM
  2. Paint for Trailer
    By 94BULLITT in forum Trailers & Transportation
    Last Post: 08-03-2011, 09:04 PM
  3. Bri-Mar Trailer Paint Falling Off
    By troyandcarol in forum Trailers & Transportation
    Last Post: 07-10-2010, 09:35 AM
  4. Trailer Paint
    By Quickdraw in forum Trailers & Transportation
    Last Post: 06-17-2008, 12:16 AM
  5. How to re-paint a trailer hitch?
    By LGinIA in forum Related Topics
    Last Post: 04-11-2006, 08:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
