Results 1 to 9 of 9
  1. #1
    Elite Member kebo's Avatar
    Join Date
    May 2006
    Posts
    2,867
    Lexington, SC
    2001 John Deere 790 4x4, bar tires
    Default My Z71 after some mod's to it......
    I bought this nearly new '13 Z71 last Memorial Day and have since had some time to do a few things to it..... First, I had a Rough Country 3.5" lift kit installed. The next thing was a set of nice chrome rims that I got off of craigslist. Then had some Falken WildPeak 285-65-18 tires mounted on them. Then I bought some stainless steel 3" step rails to make it easier to get in the cab.
    The next step was to get a set of Bushwhacker pocket fender flares on order, then get them painted to match the factory paint. Had to remove the Z71 decals because the flares would partially cover them up. May order some new decals off the internet one day. The only other thing I have done to it up to this point is to order a Range V8 AFM disable module. This is a little cheater box you can get to disable the AFM on these 5.3L engines.
    After I had bought the truck, I found out that the 5.3L engines had been having an oil consumption issue. Not every engine has this problem, and GMC has done some fixes for it, but there is still no solid evidence to show that the problem has been fixed in the 13 year models. From what I have read, it seem that the cylinders that have the oil consumption issue are the ones that get switched off when it's in V4 mode. The Range V8 simply disables the V4 mode fulltime, as long as it's installed in the diagnostic port. You don't get anymore HP, but it runs better and shifts smoother all the time because it never goes into V4 mode now. Hopefully, this will keep my engine from ever experiencing the oil consumption issue!
    Anyway, that's about it for now. I do have a chrome bug shield sitting in the garage that I just ordered and have yet to install. After that, I might get a stainless bull bar to go on the front. Eventually, I will get a spray in bed liner, but that can wait awhile. That should about do it!!
    My Z71 after some mod's to it......-chevy-flares-002-jpg
    Nothing could be finer than riding my JD790 in South Carolina!!
    2001 John Deere 790 4x4 with Model 70 FEL, 5ft International World Agritech bush hog, 5ft Wallberg BB, 5ft Frontier disc harrow, 5 1/2ft Cultipacker, 5ft Sitrex finish mower, Leinbach PHD with 9" & 12" augers, Leinbach middlebuster, Leinbach #11 Field Cultivator, custom 3pt handi-hitch, clamp on bucket forks, Pat's Easy Change.
    It's not how slow you mow... it's how well you mow slow!!
  2. #2
    Super Member timswi's Avatar
    Join Date
    Nov 2008
    Posts
    5,672
    Beaver County Pa
    Kubota BX23 TLB, Kubota RTV1100, Kubota Z724 & Polaris Sportsman 570 Touring
    Default Re: My Z71 after some mod's to it......
    Lookin' good...Not overdone, just right.
    BX23TLB with 54" MMM
    RTV1100 with 72" Power Angle Plow
    Z724 ZTR
  3. #3
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default
    Were you seeing oil consumption?
    Chris
  4. #4
    Platinum Member Loadstar's Avatar
    Join Date
    Mar 2012
    Posts
    764
    Evansville, IN
    Ford 640
    Default
    (shooting from memory) I believe there is a revised valve cover available from gm for those to correct the issue. Looked like it just had a windage tray in the revised one.
  5. #5
    Join Date
    Mar 2012
    Posts
    764
    Evansville, IN
    Ford 640
    Default
    Nevermind after 11 they come with the revised valvecover/PVC so you should be in the clear!
  6. #6
    Super Member dodge man's Avatar
    Join Date
    Oct 2008
    Posts
    5,202
    West central Illinois
    Kubota BX2350
    We have a couple of Chrysler products that switches from 8 cylinders to 4 cylinders, they call it MDS. On my Challenger I turned it off with my tuner but I was shocked at how much impact it made with my fuel mileage. I don't have an exact number but I'd put it at about 2 mpg, maybe a little more or less.
    Dave,
    BX2350
  7. #7
    Join Date
    Mar 2012
    Posts
    764
    Evansville, IN
    Ford 640
    Default
    Quote Originally Posted by dodge man
    I believe my 1978 IH loadstar idles on 4 and loads on 8 also.
    Op you put pics of your truck up?
  8. #8
    Join Date
    Mar 2012
    Posts
    764
    Evansville, IN
    Ford 640
    Default
    Never mind just loaded.. Looking good!
  9. #9
    Join Date
    May 2006
    Posts
    2,867
    Lexington, SC
    Quote Originally Posted by Diamondpilot View Post
    Chris
    no, truck only has 4500 miles on it. if it is going to use oil, it typically starts around 40k miles. if I understand the problem correctly, this v8 module should make sure it never does develop the early oil consumption issue. if nothing else, the module improves driveability because it always has full power and never switches down to the v4 mode.
Similar Threads
  1. TC30 Mod's Tool Box, Step,Cup Holder
    By yoder in forum Customization
    Last Post: 07-24-2013, 06:57 PM
  2. Anti-Scalp Roller Mod's?
    By RET in forum Kubota Owning/Operating
    Last Post: 07-20-2006, 07:39 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
