downslope
- Joined
- Mar 11, 2008
- Messages
- 644
- Location
- NY
- Tractor
- MF TO-35, Ford(s) 2000, 8N, 9N, White 2-70, NH TD75D, JD 5045D
I have to replace the 6 tires on a Chevy C30 dually that we only use 1-2,000 miles per year.
They are currently tube-type with the retainer rings. The wheels are in good shape. The current tires are 7.50X16 bias. The truck is solid good condition.
What to do without spending more than the truck is worth?
I think my cheapest option is to keep my rims and install new 7.50X16's with tubes in them. Is that an OK route to take?
I have looked in wrecking yards for tubeless dually rims but I'm having a hard time. I think I need rims that are pre-2000 that have 9/16" bolt holes. Every wheel I've located so far has 5/8" bolt holes, probably from later years.
I can buy new steel wheels (Accuride) with the proper bolt pattern and hole sizes but they are over $100 each.
I see Greenball makes a bias truck tire in 7.50 size LR E for a little over $100 each. New Greenball Hiway Master 7 50 16 10pr TL BSW Tires | eBay Anyone have experience with Greenball tires on a truck?
Equivalent size new radials in name brand would probably run $150-$200+ each. It would be nice to find some correct rims with good used tires on them, but it may be wishful thinking. In the meantime I think I'll keep looking for proper used rims; I shouldn't use the ones with 1/16" oversize stud holes, even though the hub pilot is correct, right? I can get 6 of them for $150.
