N80
Super Member
This weekend I am purchasing a new 19' 8k# gvwr, open, flat bed, car/tractor hauler. It will be used mostly to haul my car to the track, occasional use for other projects and rarely to haul my tractor. I'm guessing it will get used maybe 5 or 6 times a year.
The rest of that time it will be sitting in my open, sand floored tractor shed and the tongue will probably actually be sticking out from under the roof line of the shed.
What do I need to know about storage for this trailer? It has easy lube hubs so I will certainly make sure those are well lubed prior to and after storage. Does anyone make a cover to protect the plug end of the wiring harness? These always seem to have dirt, spiders and bugs down in them. Is there any benefit to buying jack stands to keep it raised up off the tires (it has radials)? Should I keep tire pressure at normal levels or lower for storage? Is it worth it to buy tire covers? It will get morning sun from on the left side.
Any other tips recommended? I don't want this thing to turn into the rusted unreliable-when-I-need-it-most that most infrequent-use trailers usually turn into.
Thanks for any help.
