LD1
Epic Contributor
Need a little help and figured I'd see what you guys think.
Working on a 2009 Nissan sentra 2.0.
Symptoms were it would barley run, and white smoke with strong coolant smell, low coolant (so it's burning it).
Was 100% sure it was the head/gasket. So didn't diagnose any further.
Tore off the head, and clear evidence that #1 and #4 were burning coolant. But the gasket didn't look blown at all. Had he'd checked out....no cracks and not warped.
Not sure if coolant passes through the TB or intake manifold, but even if so, all cylinders should show signs of burning coolant and not just 1 and 4.
At a loss here. Don't really want to spend $200-$300 to it back up without actually having found/fixed anything.
Don't really have a sufficient way to check the block, and pulling it out is a whole lot more work. Am I overlooking something?
