I purchased an '02 Branson 4020 with loader and backhoe and plan to tow it 1,200 miles to our future retirement home. Will be on good interstate the majority of the time with no big elevation passes (I-90 across SD; WY and MT). Tow vehicle will be my 2015 Chevy 3/4 ton Crew Cab 4x4 Diesel. Truck is bone stock.
I am borrowing a new 2016 LoadTrail 81"x20' tilt trailer (bumper pull). Trailer is not setup for a weight distribution hitch. It has twin 7000lb axles with electric brakes. Trailer says 12,000 lbs GVWR and their website says 14,000 GVWR. Trailer weight is 3,725 lbs. Still waiting on the exact weight spec of my backhoe but I believe the weight of the tractor with all implements is 6,700 to 7,000 lbs.
So the total trailer weight will be under 11,000 lbs.
My truck has the factory brake controller.
I have a lot of experience pulling out 28' Toyhauler with my truck. It has a very heavy tongue weight but probably no more than 8,500 lbs when fully loaded for a trip (including the ATV). My truck pulls it just fine but I use a very nice Reese WDH. Unfortunately my hitch is with the trailer 1,200 miles away plus the brackets require the trailer to be drilled I think.
My truck has a max trailer weight of 17,100 lbs limited to 13,000 lbs if bumper pull. Max bumper pull tongue weight is 1,500 lbs so I'm within those specs using 10% loaded tongue weight.
Are these tilt trailers designed to be used without a WDH? I guess I could try to rent or borrow a WDH with clamp on brackets or I could get airbags put in my truck.
I do have a tongue weight scale and plan to load the trailer properly and chain down the tractor at each side of the axles and put straps on the implements.
Any advice is greatly appreciated. I take safe towing very seriously and I will have my wife and dog with me so need to be extra safe.
