OP
RichM752
Gold Member
- Joined
- Dec 24, 2012
- Messages
- 401
- Location
- Mount Shasta CA
- Tractor
- Kubota L47TLB, Two Labs, and a Martin OM28
I was looking at that same trailer recently. How balanced is the gravity tilt. One of the things I need a trailer for is hauling water and am wondering if with water balance would I be able to unlatch, get on the very back of the tail and have it tilt down, thus allowing the water to fully drain? When hauling water at -35 degrees fully draining the tank is important. Power tilt is probably out of my budget.
If water tank was mobile, and you have a means of controlling movement, once tipping point is reached it's easy to control rate of tilt. At least it is for me loading/unloading my tractor. Finding that point with a stationary tank might be tricky, considering how much it would weight full and placement on trailer in full condition. I find that my 175# is sufficient weight to tilt empty, as long as I'm on level ground. On a slight downhill grade its a bit of a chore. I hope this helps. I'm very satisfied with the trailer. It's a quality build, tracks strait, brakes well, and easy to maneuver I especially like the large lockable storage box.
