coobie
Super Member
- Joined
- Sep 19, 2004
- Messages
- 6,427
- Location
- S.Michigan
- Tractor
- Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
I clay bar it once a year.Oh the pain...Old school I guess always wax it..Cleaning it, is necessary. Waxing isn't.
You can save yourself a lot of trouble, by eliminating the later.
Modern automotive finishes do not require wax to seal them.
Modern waxes generally contain little more than silicone, and mostly lack any ingredients to clean the paint.
Cleaning the paint is what is important. Clean it, with a clay bar and soapy water, and apply a paint cleaner like a Meguiars Deep Crystal polish, or Meguiars Cleaner Wax, (ignore the name, it's just a mild polish), as necessary. These products will remove minor oxidation, and wear. Skip the final step, which is the wax.
There are lots of other good products out there to do this with.
If you are not doing the deep cleaning before waxing, you are neglecting the part that really matters, and not actually doing anything more than applying some silicone, while the pollution, and dulling wear builds up.
When you learn to use the above products, you can periodically go over it, and properly maintain your finish, without ever killing yourself.
