LD1
Epic Contributor
Hoping someone can offer some assistance on some multiple electrical (lighting) issues I am having.
It would probably be easier to list off the lights that DO work, but here is a list of those that dont:
Left Tail light
Left turn/brake
Both backup lights
Center high mount stop lamps
Both front turn signals
Right high beam
Left low beam
The headlight "bulbs" are fine. Took them out, filaments intact. Both bulbs will light up on high on the left side, but neither will light the low beam on left side. They will both light the low beam on the right side but not the high. So not the bulbs. Something in the wiring.
The left taillight/brake/turn assembly......it all works when plugged into the right side, so not the circuit board or bulbs in that either.
Dont know on the backup lamps or front turn signals because NEITHER side works so I cant swap to test bulbs. But filaments are intact as well, and given the issues with the other lights, I dont suspect the bulbs.
Some googling lead me to a connector under the driver side floorboard as a potential problem area/corrosion/etc. But took that apart and all look clean and tight.
Given the numerous lighting issues that seemed to happen all at once, I am inclined to thing this is a single problem area. But dont know what is common to all or most of the things I listed.
Aint gonna have time to look into anthing til tomorrow, got the shop tied up for my sons birthday party here in an hour or so. And havent put the multimeter on anything yet. Just looking for some so insight before i get started into it tomorrow.
And if anyone has a link or access to a wiring schematic that they would be willing to share, that would be awesome too.
Left Tail light
Left turn/brake
Both backup lights
Right high beam
Left low beam
