Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 39
  1. #21
    Epic Contributor MossRoad's Avatar
    Join Date
    Aug 2001
    Posts
    34,789
    South Bend, Indiana (near)
    Power Trac PT425 2001 Model Year
    Default Re: why have 5th wheel and gooseneck couplings?
    Quote Originally Posted by Xfaxman View Post
    Big difference.
    Gooseneck, old style plate:
    Attachment 548413
    New style:
    Attachment 548409
    Attachment 548421
    5th wheel:
    Attachment 548415 Attachment 548416
    Picture goodness!
    MossRoad
    Click On My Little Tractor
    To See Pictures And Videos
    Of It In Action!!!
  2. #22
    Gold Member
    Join Date
    Apr 2017
    Posts
    309
    Roy, UT
    LS XU6168CPS
    I think it comes down to the simple fact that 5th wheel is easier. They donít have to be perfectly aligned, and can be a little off in height and still work. As the truck is backed up, the pin is forced into position and the jaws latch automatically. Then no safety chains to have to hook up. Which a gooseneck, you have to get that ball right under the hitch for it to drop down on it.
    With extended cab pickups, itís hard to see to get it right the first time. But you can see a 5er hitch pretty well and do it in one shot.
  3. #23
    Join Date
    Mar 2017
    Posts
    213
    Northern California
    Branson 3520h
    I wouldn't be surprised if the early goosenecks were farmer DIY jobs... that said, my rather uneducated opinion is that because the gooseneck allows more articulation, it handles rougher territory better, and there's a lot less space taken in the bed of the truck - just this (usually) vertical post. A fifth wheel hitch takes up a lot of space.
    I also wouldn't be surprised if the over-the-truck-bed portion of a lot of gooseneck trailers is higher than the equivalent on a 5th wheel, which also allows for more use of the truck bed. A corollary to this is that the fifth wheel hitch's lack of side-to-side tilt (mostly) allows the trailer to be closer to the bed than the gooseneck, which gives better clearance for a larger RV or semitrailer.
    Overall it looks like the gooseneck was designed more for rural use, and the fifth wheel originated for the semitrailer and was chosen for RVs because of volume considerations.
  4. #24
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,984
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Quote Originally Posted by 3Lfarms View Post
    I think it comes down to the simple fact that 5th wheel is easier. They don’t have to be perfectly aligned, and can be a little off in height and still work. As the truck is backed up, the pin is forced into position and the jaws latch automatically. Then no safety chains to have to hook up. Which a gooseneck, you have to get that ball right under the hitch for it to drop down on it.
    With extended cab pickups, it’s hard to see to get it right the first time. But you can see a 5er hitch pretty well and do it in one shot.
    I fastened a short piece of aluminium rod to an old speaker magnet. Set it in front of the gooseneck ball, back up using the rearview mirror, keeping the rod centered on the trailer hitch. When the rod moves, stop and lower the hitch onto the ball.
    Hold "Ctrl" (Control) and click on a picture or a Link, to open it in a new Tab.
    My Avatar, the TORO+Loader:
    Kwik-Way FEL and TORO Groundsmaster Put Together
    V417 Compact Telehandler: ​(This replaced my tractor): The best machine to do what I need a machine to do
  5. #25
    Veteran Member Bigfoot62's Avatar
    Join Date
    Aug 2008
    Posts
    2,218
    W. Central Louisiana
    JD 5083E; JD 5085M; NH TN70A; Ford 2600
    I DON'T use both. My only 5th wheel trailer is the RV, and I put a G/N adapter on it. I have a 5th wheel on the Peterbilt, but can't stand the thought of a 5ver hitch in the bed of my pickups.
    Yes, the G/N is a little bit harder to hook up and requires safety chains, (and I think that's stupid) but it's worth it not to have to deal with the 5ver hitch in the bed.
    '12 JD 5083E Cab MFWD FEL
    '10 JD 5085M Cab MFWD FEL
    '07 NH TN70A MFWD FEL
    '81 Ford 2600
    '18 Kubota RTV-X900
    Vermeer 504R round baler; JD 265 & Kuhn GMD 600 disc mowers; Sitrex V-10 rake; Krone 5.52 Tedder; Hardee 10', Rhino 7', & Modern 5' rotary mowers; JD 13' & Ford 6' tandem discs; HayKing 10' rennovator plow (sub-soiler); etc, etc.
    My other tractor is a '01 Peterbilt 379.
    "I've come to the point in my life where I can't remember if I've lost my horse or just found a rope."
  6. #26
    Veteran Member bdog's Avatar
    Join Date
    Mar 2004
    Posts
    2,041
    Texas
    John Deere 4440
    I haven't seen one in over 20 years but an old friend had a gooseneck horse trailer that was inverted. The ball was on the trailer and there was a V shaped channel in the bed with a socket for the ball at the point. You could back up not perfectly aligned as long as the height was close and it would slide into place. A simple pin and clip like what holds a receiver hitch in secured the ball. It was very easy to use and the plate part in the truck didn't take up much real estate.
    1980 John Deere 4440
    2006 John Deere 550 J dozer
    2016 John Deere 333E compact track loader
    2018 John Deere 35G excavator
  7. #27
    Gold Member
    Join Date
    Jul 2008
    Posts
    393
    Boise, ID
    JD 2320
    Quote Originally Posted by ning View Post
    my rather uneducated opinion is that because the gooseneck allows more articulation, it handles rougher territory better.
    This is what I have always been told. The gooseneck is better for the farmer/rancher/construction because they could be out in the field and need to articulate. I do also think it is the ease of conversion. Need to pull the horse trailer and then need to get a load of hay in the back of the pickup, either ignore the ball or take it out and then you can load the back of the pickup without needing to remove a big 5th wheel hitch by yourself. Need to go fencing, pretty easy to throw a bunch of posts in the back of the pickup and not need to do anything.
    JD 2320 with 200CX loader, 655 tiller, 62" MMM
    Oliver 77 Row Crop Fleetline, wide front
    Husqvarna 372 24" full chisel chain
    I miss the Oliver 770
  8. #28
    Join Date
    Mar 2010
    Posts
    220
    Ozark Alabama
    07 Kubota L3400
    just in case somebody is interested, many companies now make a 5th wheel that fits in your gooseneck "hide-a-ball", B & W Companion RVK35 5th Wheel Hitch for Pickup Trucks | SuspensionConnection.com
  9. #29
    Elite Member sandman2234's Avatar
    Join Date
    Dec 2005
    Posts
    4,558
    Jacksonville, Florida
    JD2555 and a few Allis Chalmers and now one Kubota
    I have 2 flatbed utility trailers (over 20 feet) that are one of each, and I actually prefer the fifth wheel hitch when it comes to hooking up by a long shot. Now I haven't been ingenious like Xfaxman and made a guide that would make the gooseneck easier to hook up, so maybe I will try that. They both pull equally well (although I have way less miles with the gooseneck). Although the gooseneck allegedly allows more travel when traversing uneven ground where the truck leans one way and the trailer leans to the other side, a 5th wheel doesn't have any issues with that either, because the suspension (and tires) of each vehicle should absorb the difference in road dips. Tractor trailers (semi-trucks) do not have any side to side loading provisions. Their 5th wheels only move in a forward to backward movement (on pivot pins). Some are on sliders that are adjustable by the driver to allow the hitch to move forward or backwards on the frame rails, which is to allow the weight of the load to be moved to help keep the weight properly positioned (legal requirements on max weight allowed on each axle). Moving the 5th wheel plate forward moves weight from the drive axles to the front steer axle, or vice versa. On some trailers (mostly container haulers) the 5th wheel pin is located deeper from the front bulkhead of the trailer and requires the 5th wheel hitch to be moved rearwards on the frame rails to keep mudflap to landing gear distance in a workable distance.
    The B & W Companion hitch just listed looks interesting, but my 5th wheel comes out with 4 pins, so easy enough. One thing I wonder about on the B & W hitch, is will those 4 neoprene pads which will sit on the sheet metal in a bed, when loaded to a max amount, put dents in the bed of the truck?
    David from jax
    A serious accident is one that money won't fix.
  10. #30
    Gold Member
    Join Date
    Apr 2017
    Posts
    309
    Roy, UT
    LS XU6168CPS
    Quote Originally Posted by sandman2234 View Post
    David from jax
    The two feet are actually about 2í long and sit in the bottom of the groove in the pickup bed and span across the supports under the bed. The pads are designed so they are adjustable to the rib spacing of each truck.
    In a new truck, you may get a little bit of bending of the bed, but in my rhino lined pickup, you canít tell the 5er hitch was ever installed and I pull a 20k lb trailer.
Similar Threads
  1. I Need Advice on a 5th Wheel to Gooseneck Adaptation
    By Iplayfarmer in forum Trailers & Transportation
    Last Post: 09-25-2013, 07:18 PM
  2. 5th Wheel and Gooseneck NOT the same thing.
    By wvpolekat in forum Trailers & Transportation
    Last Post: 06-11-2011, 03:35 PM
  3. Gooseneck, 5th Wheel, or Bumper pull?
    By Charlesaf3 in forum Trailers & Transportation
    Last Post: 02-28-2011, 01:26 PM
  4. Gooseneck and 5th Wheel all in one (no 5th holes)
    By Anonymous Poster in forum Related Topics
    Last Post: 02-26-2003, 08:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
