Fallon
Super Member
Ya, there are issues with a completely tilting deck balanced in the middle. My 16' was this way. It's only saving grace was a really long tongue I could set the bucket/loader on. The tongue functioned more or less like a fixed deck up front.
I couldn't put much on the back of the deck & still get the deck to tip forward (made sure I never had negative tongue weight).
A decent fixed deck in front will mitigate most of the drawbacks from a tilting deck.
16' was too small for my 3,000lbs of L3200. I assume the trailer was made for a very heavy compact skid steer or mini-ex as it had a pair of 7k axles under it. Somehow I did manage to fit & balance a 10k+ lbs 40 year old backhoe on it. That was sketchy though. Had to remove part of the pipe rack on the F250 & no tight turns. Was only 10 miles going really slow on back roads though.
No tractor hauling photos of the new trailer, but I did haul it up the side of a 5,000' mountain on dirt roads with the Tacoma around switchbacks so tight I only had 1-2' of clearance on each side to pick up that radio tower. Pulled beautifully. Use the Taco for light jobs as its nicer to drive. The bearer F250 is used for heavier hauling. Got it after pulling the L3200 with the Tacoma a couple times.
