Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. #21
    Super Member dfkrug's Avatar
    Join Date
    Feb 2004
    Posts
    5,728
    NorCal
    05 Kioti CK30HST w/ Prairie Dog backhoe
    Default Re: 7 pin connector
    Quote Originally Posted by Morning Wood View Post
    The 7 pin round with round connectors is a better plug than the 7 pin round rv style plug. Keeping everything cleaned off and good electrical connections is really all it takes though.
    I like those connectors with the round pins. I guess my 7-pin connector is "RV-style" with round center pin
    and other pins flat. A round steel brush would certainly be easier for cleaning.
    I have tried sealing my trailer-side plug, but it seems to trap the moisture inside. Maybe I will add some lube,
    as suggested.
  2. #22
    Join Date
    Nov 2005
    Posts
    2,367
    Liberty, Kentucky
    None at this time.
    Quote Originally Posted by joeu235 View Post
    I was pulling a 14,000# load. I was going down the steepest decline within 100 miles and my truck said "Trailer Disconnected". My first thought was "Why the F right now" Luckily my truck has an exhaust brake so I was able to maintain 25 miles an hour until I got to the bottom. I pulled over at a gas station and wiggled the connector around and it started working again. I searched on internet and found a connector that the wires are molded onto it instead of screwed onto the end. I think I'll replace the connector with one of these.
    I've started soldering every connection as well.
    18 wheeler trailers have to have a more reliable system than the POS on lighter duty trailers.
    Big trucks use connectors with all the pins round. They too eventually do have issues with wear. In the past, I have had to wrap a small bungee around the weather flap on the trailer and the plug to stop the lights from blinking on every bump. More so for operators that swap trailers, the constant plugging/unplugging keeps the contacts from building up crud.
    The recepticle end under a pickup or the like is in a pretty harsh environment. Moisture seems to collect but not drain too well. As mentioned, some kind of spray or dialectric can help. I have had less issues with a gooseneck plug up by the ball then with BP trailer plugs on the back end.
  3. #23
    Super Star Member two_bit_score's Avatar
    Join Date
    Dec 2008
    Posts
    10,380
    Texas - from the brush and pear to the piney woods
    John Deere 110 TLB
    Quote Originally Posted by JPRambo View Post
    Google "teminal connector cleaner" its a wire brush for inside the connections.
    Sure not cheap either.
    TBS
  4. #24
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    7,046
    Northern Vermont
    Kubota, Case, Deere
    I wish someone would make one with stainless steel, not brass contacts. The salt up here kills the brass.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
  5. #25
    Join Date
    Jul 2003
    Posts
    1,871
    SW Indiana
    Ford 1920 4x4 (traded in on Kubota). Case 480F TLB w/4 in 1 bucket, 4x4. Gehl CTL60 tracked loader, Kubota L4330 GST
    Teachu2's .17 caliber bore brush solution was $2.49 at Rural King today.
  6. #26
    Join Date
    Dec 2008
    Posts
    10,380
    John Deere 110 TLB
    Quote Originally Posted by jmc View Post
    Well I have one. But a dedicated pin plug cleaner brush would be handy.
Similar Threads
  1. My 7 pin connector has no wire on pin #4, 5065e
    By Rmd8136 in forum John Deere Owning/Operating
    Last Post: 05-24-2017, 04:08 AM
  2. 7 pin connector corroded?
    By Wayne_H in forum Trailers & Transportation
    Last Post: 10-27-2011, 09:13 AM
  3. 12 pin to 6 pin attachment connector
    By overseas in forum Bobcat Construction Equipment
    Last Post: 02-18-2011, 03:02 AM
  4. 12 pin to 6 pin attachment connector
    Last Post: 05-08-2010, 08:15 PM
  5. 7-pin and 14-pin connector conflict
    By Rolando in forum Toolcat
    Last Post: 08-09-2009, 11:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
