Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    8,059
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Default Re: Sliding axle gooseneck
    Right, more pictures for the discussion. A gooseneck rollback:
    Sliding axle gooseneck-gn-rb-2-jpg Sliding axle gooseneck-gn-rb-3-jpg Sliding axle gooseneck-gn-rb-jpg
    Hold "Ctrl" (Control) and click on a picture or a Link, to open it in a new Tab.
    My Avatar, the TORO+Loader:
    Kwik-Way FEL and TORO Groundsmaster Put Together
    V417 Compact Telehandler: ​(This replaced my tractor): The best machine to do what I need a machine to do
  2. #12
    Join Date
    Jan 2015
    Posts
    86
    SW Idaho
    2008 Kubota M59
    Yep. Those trailers are pretty much what I'm looking at. The one Im considering has 3 axles with single tires. I'm just curious how well my truck would pull forward to raise a heavy load up over the 3 axles with the trailer brakes on. I'd hate to use the winch every time, and if I had 8 tons of hay stacked on there and it wouldnt come up (truck tires spinning in gravel, etc,) theres no way to run the winch cable under the hay, around the pulley, and onto the back of the tandems. That would be easy to load and unload the hay tilted down, though.
  3. #13
    Join Date
    May 2005
    Posts
    2,232
    N. E. Florida
    Quote Originally Posted by ovrszd View Post
    Sliding tandems on a semi trailer isn't what this discussion is about. The ability to tilt and drop the bed to the ground is what's significant. X has posted some great pics!!!
    SORRY IF I BORED YOU WITH FACTS ABOUT A SIMILAR INDUSTRY!
    YOU SHOULD GET A JOB AS AN INTERNET COP!
    EASY TO SEE HOW YOU GOT OVER 17,000 POSTS.
  4. #14
    Super Star Member ovrszd's Avatar
    Join Date
    May 2006
    Posts
    17,917
    Missouri
    Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
    Quote Originally Posted by Stimw View Post
    Wow, where'd that come from?
    Richard
    "Happiness isn't having everything you want, it's wanting everything you have."
  5. #15
    Join Date
    Nov 2005
    Posts
    2,387
    Liberty, Kentucky
    None at this time.
    The original post mentions sliding axles then the op got huffy when Stimw as well as myself mentioned mechanical slides. What with very limited info about the trailer in the original post, I for one was trying to be helpful. Hope your trailer works out for you. Goodbye!
  6. #16
    Join Date
    Jan 2015
    Posts
    86
    SW Idaho
    2008 Kubota M59
    I dont get huffy about much, especially online discussions about trailers. I appreciate any input from anyone willing to contribute!
  7. #17
    Join Date
    May 2006
    Posts
    17,917
    Missouri
    Quote Originally Posted by QRTRHRS View Post
    I had to reread all the posts. Didn't see anything huffy from the OP at all. Only huffy post I see is stimw's yelling response to me. Still don't know what that was about.
    I'm with the OP, sliding axles aren't worth getting upset over. But then maybe I missed something.
    Richard
  8. #18
    Join Date
    Nov 2006
    Posts
    164
    Napa, Ca
    2006 Kubota L3830
    Quote Originally Posted by Morning Wood View Post
    I壇 imagine the winch would move the axles. Neat concept, but if you are just pulling your tlb and hay might be unnecessary. If you were hauling slot of different stuff and really needed to screw with tongue weight than I could see the need. I知 not a fan of the really long ramps for a flat deck trailer. They will be really heavy.
    I believe semi truck slide axles slide by pulling the pins, setting the trailer brakes, and driving the tractor forward or aft.
    I've seen low flatbeds where the axles slide all the way forward for loading, they appeared to be mechanically assisted.
Similar Threads
  1. Ford 750 front axle sliding on pivot pin
    By Moondoggy in forum Parts/Repairs
    Last Post: 10-22-2016, 10:26 AM
  2. Gooseneck with a single dually axle?
    By LD1 in forum Trailers & Transportation
    Last Post: 05-29-2016, 02:09 AM
  3. sliding gate
    By crazymike in forum Build-It Yourself
    Last Post: 11-30-2010, 09:01 PM
  4. Troy-Bilt Horse Axle Sliding
    By Bob in MO in forum General Lawn & Garden
    Last Post: 05-02-2008, 08:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
