rustyshakelford
I had a dump trailer that I ended up selling cheap to a buddy that was in a bad bind. I had just done a ton of work to it and added a Honda hyd pump along with new tires/wheels etc. finally had it where I wanted it. Well that痴 gone and I was still needing something to haul rock for my road and whatever else I needed.
When we were building our house we had a neighbor that hauled smaller roll offs. In the 15-20 yard range. I have seen his stuff parked for the last year or so. Out of the blue he calls me last Friday and was asking about fertilizing his pasture. While we were talking I asked him about his stuff. He said he壇 love to sell it as it痴 just sitting. He spit balled a number. I went over yesterday to look at everything.
It痴 in way better shape than I could致e guessed. Is basically built like a big roll off truck. All the new ones have an elec winch, this one has the two hyd cylinders that run the cable.
So far I知 going to replace all the hyd lines and there痴 a ton. Everything is hyd even the jack on the front. Rebuild the two lift cylinders, blast and paint or beeline the frame and maybe rewire it. The pump needs a new carb, oil change and flush the hyd oil. Also need to order a hyd reservoir cap. It has a weird set up with a filter or something. Someone cross threaded the cap and it痴 no good. Forgot to get a pick with a container on it. It has 3 decent ones and one that is pretty rough. Will probably turn the worst one into a flatbed
Also put a bigger beam on my gantry yesterday morning. Ended up coming in real handy
Brett
Brett
