davesisk
Does anyone have any advice on retrofitting surge brakes to a trailer than currently doesn't have brakes? I've got a 5x10 single-axle trailer that is legally rated for 2990 lbs, but actually has a 3500 lb axle and 1800 lb tires. I get a little nervous with even 2000 lbs on it even though I could theoretically pull more (my Isuzu Rodeo is rated for 3000 lbs tow weight and 500 lb tongue weight). I've heard a bit about surge brakes, which (to my understanding) work by having a sliding tongue with a hydraulic ram in it. When you apply the brakes on the vehicle, the inertia of the trailer pushing on the tongue pushes the ram, which applies pressurized fluid to the brakes on the trailer. Sounds awefully reliable and problem-free in concept. I've thought about electric brakes, but it sure seems difficult to keep the lights on the trailer working, so I'd imagine electric brakes would be just as problem-prone...I could be wrong of course.
Anyone else using surge brakes? Are there kits to retrofit surge brakes that anyone has used or knows of?
Thanks!
Dave
Thanks!
Dave
