Iplayfarmer
Super Member
I have a small Iseki TX1500 with a FEL and tiller. The tractor specs say it weighs about 1200 pounds. I would guess that with the FEL and tiller it weighs in a little over 1800 lbs. I've been hauing it in the back of my 1/2 ton pickup. Needless to say it's not my favorite experience loading and unloading the tractor from the back of a pickup truck.
In fact... on Saturday I was unloading and one of the ramps slipped when I was about halfway down. There I was dangling a rear wheel in mid air, praying that the front wheel would hold. The airborne wheel was spinning freely. I stepped on the differential lock and backed until the two rear wheels were on firm ground. Then the front wheel slipped off the ramp. The short version of the rest of the story is that the whole tractor was quickly on the ground and there's not much left of the ramps. The truck is O.K.... not even a scratch.
I got a trailer last night to haul my tractor. The question I have is "How much work am I going to have to do on it?" It's a home-made job I bought off a guy down south of here. The frame is strong, and there are cross members running widthwise every two feet along the whole length of the trailer. The axle is a mobile home axle, so it's pretty hefty. My only concern is the decking. There are two layers of plywood. The bottom layer is 1/2" and the top is 3/4". The wood is old, but it doesn't look like there's any dry rot or anything.
Unlike most of you, I'm not a welder, but I'm pretty good with wood. I had originally thought about ripping off the old plywood and beefing up the deck with some 4X4 "joists" between the cross members along where the wheels will be. Then I'd re-do the deck with 2x12 planks (or just put back the old plywood).
Do you think I need to spend the time and effort to re-build this decking, or do you think that the 1 1/4" of plywood will hold? Does anyone have better ideas for re-building the decking if that's the route I go? I do know a few good welders around, but then I'm paying for time instead of wasting it myself.
