Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Gold Member
    Join Date
    Oct 2000
    Posts
    367
    Northern California
    B21
    Default trailer hitch on backhoe?
    I see many ads for trailer hitches on drawbars at the rear but I use the backhoe all the time and don't want to take it off just to move a trailer.
    We have an enclosed trailer that gets storedin a very tight spot that requires every ounce of my backing up going forward skills when attached to the pickup.
    I'm thinking if I could attache the trailer to a ball somewhere on the backhoe bucket - the tractor is shorter and MUCH more manuverable - I should be able to place that puppy on a dime.
    But where, how to mount a ball on the backhoe without interferance problems?
    Perhaps some sort of a slot/sleeve that the ball hitch could easily slide into when needed.
    I know there are brilliant solutions out there amongst the TBN fabricators
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Banned HomeBrew2's Avatar
    Join Date
    Dec 2004
    Posts
    1,896
    Dunlap, CA
    Kubota BX23
    Default Re: trailer hitch on backhoe?
    Seems like somebody did that but can't remember. Did you try a search? In a pinch one time I just found an old swivel link thingy that a ball stem would go thru then wrapped a chain around the bucket somehow that held well and just towed an enpty trailer around. Since then I drilled a hole in my FEL cutting edge to mount a ball ... very quick, easy and works great ... and I like pushing the trailer rather than pulling it!
    Cheers!
  4. #3
    Gold Member
    Join Date
    Oct 2000
    Posts
    367
    Northern California
    B21
    I like the manuverability of a backhoe instead of a fel
    I havnt founf anything in a search
  5. #4
    Join Date
    Dec 2004
    Posts
    1,896
    Dunlap, CA
    Kubota BX23
    Ok, if it's been done or thought of, this is the most likely your guy: GuglioLS.
    Hope that helps, cheers!
  6. #5
    Join Date
    Feb 2005
    Posts
    1,770
    I made a simple device that I attach to the center of my loader bucket and it has a ball on it. I now see that they sell these.
    Mine is simple, but you would probably have to have a welder.The ones you can buy use a screw clamp to hold them in place.
    for mine I used a pe=ice on steel angle iron and set the ball on one end and the other end drilled a small hole 3/8 in the bucket . and used a bolt to attach it. I just reciently welded the bolt solid and drinlled it out to take a lynch pin. This makes it easy to put on and off.
    My trouble is remembering where I put it last..LOL
    The advantage to this type is that I can see the trailer and its much easier to jog it around.
    I could get a picture if youd be interested.
    Allan
  7. #6
    Join Date
    Jul 2003
    Posts
    1,993
    MN
    Ford 960, 7700, TW20, 1720; IHC H, 300; Ollie S77
    </font><font color="blue" class="small">( I like the manuverability of a backhoe instead of a fel
    I havnt founf anything in a search )</font>
    I don't understand this comment - there is a difference between a real backhoe, a Tractor-Loader-Backhoe, and a loader tractor, but I can't tell what you are prefering....
    Anyhow, there are several clamp-on hitches that will work if your trailer is not too big a load. Look to the advertisers here, or anyplace that sells loader attachments such as pallet forks, esp the clamp on forks. I've seen a dozen different copmanies that offer such.
    ---&gt;Paul
  8. #7
    Gold Member
    Join Date
    Oct 2000
    Posts
    367
    Northern California
    B21
    Paul
    I have a Kubota B21.
    What are the differences between a real backhoe, tractor loader backhoe and loader tractor (as they relate to this topic)?
    I have looked online but not seen what I am looking for - a simple receiver for a ball located somewhere on or near the backhoe bucket.
  9. #8
    Join Date
    Jul 2003
    Posts
    1,993
    MN
    </font><font color="blue" class="small">( Paul
    I have looked online but not seen what I am looking for - a simple receiver for a ball located somewhere on or near the backhoe bucket. )</font>
    I see. I got a bit muddled. [img]/forums/images/graemlins/smile.gif[/img]
    A real backhoe is on tracks, has the backhoe arm, and that is all. Doesn't look like a tractor at all, some will call it an excavator I believe.
    I thought you were talking about a TLB you have - like the Case or JD units, they are a beefed up tractor with a dedicated construction loader on them, dedicated backhoe on the back. There is no 3pt hitch or pto, the front axle is industrial, the hydraulics are beefed up......
    A loader tractor is what you have - with a 3pt or frame mounted backhoe on it.
    When you said you wanted to be more manuverable &amp; mount a reciever hitch on the bucket, I thought you meant you wanted to put the hitch on the _loader_ bucket, and be able to back your trailer around. It is much more manuverable that way.
    There are many companies making such clamp-on reciever hitches.
    I'm not aware of a hitch that goes on the backhoe arm/bucket. That would be rather stressfull on the geomotry of the arms &amp; hydraulics, and may not be a very good idea.
    ---&gt;Paul
  10. #9
    Elite Member SkyPup's Avatar
    Join Date
    Dec 2003
    Posts
    3,001
    North Central, Florida
    Kubota L-39 GST TLB, Kubota L3130GST, Massey 1030 HST, Kubota ZD-21 ProDecK, Two Euro VW TDIs
    A Kubota B-21 is a TLB.
    I would simply weld on a plate to the upper rear lip of the BH bucket and install a trailer ball onto that with the bucket levelled.
    I welded a clevis hook onto the BH of our L-39 TLB as seen in the attached photo, something similar with your B-21 is possible with a ball hitch... [img]/forums/images/graemlins/wink.gif[/img]
    Attached Images Attached Images
  11. #10
    Join Date
    Aug 2004
    Posts
    228
    Central Texas-Freestone/Donie
    Mahindra 5500
    MD Barb- So as to not steal this post see the post in Rural living with your name on it please.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
