Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Gold Member
    Join Date
    Jan 2005
    Posts
    288
    new london county,ct
    jd h, jd 50, jd2010,jd 790,case530hoe
    Default trailer recommendations
    i'm in the market for a landscape type trailer to haul my jd790 w/ loader and bushhog. i also plan to use it for delivering hay small squares. i'm thinking a dual axle 16 ft. should be sufficient. i will be towing it w/ a 2500hd duramax. what brands are good, 2 local tractor dealers sell big tex and bri-mar. i'm trying to stay 3k and under. thanks for any help in advance. jim
  2. #2
    Epic Contributor Egon's Avatar
    Join Date
    Aug 2001
    Posts
    20,802
    Nova Scotia, Canada
    Default Re: trailer recommendations
    Wether it will be a bumper pull or gooseneck get the largest your truck will handle. Length will come in handy when hauling bales.
    Don't scrimp on the trailer. You have a proper puller so make use of it.
    Egon [img]/forums/images/graemlins/grin.gif[/img]
  3. #3
    Join Date
    Jul 2005
    Posts
    1,302
    lower part of Md.
    JD310, ASV RC-100
    What Egon said plus, if you can, go with a tilt deck. You'll get spoiled quick not having to fool with ramps.
  4. #4
    Veteran Member JDGREEN4ME's Avatar
    Join Date
    Sep 2002
    Posts
    2,247
    Southeast PA
    John Deere 2520, John Deere X534, LT150, STX 38
    Over the years I have had two Big Tex trailers. One was a landscape trailer and the one I have now is a car hauler. I have been happy with both. [img]/forums/images/graemlins/smile.gif[/img]
  5. #5
    Join Date
    Dec 2005
    Posts
    101
    northeast kingdom vt
    kubota 2250 loader woods bh 7500 , gehl 4640 skidsteer
    farmer jim,
    I would go with a carhauler type those landscape rails will annoy you greatly when you are stacking hay. And depending on your wheel spacing on the rear 77" may be too tight to get your tractor on comfortably. Plus the gate on the back may not stand up to tractor traffic. Something to think about. Bri-mar and big tex make awesome trailers and they don't cut many corners in building them either
    kman
  6. #6
    LarryRB
    Guest
    the Bri-Mar is extreme heavy duty and will hold up easily here in New England. Big Tex trailers (pipe) type, aren't anywhere near as stout and the pipes get in the way.. There are several trailer dealers going up 395 to 101 east and just as you cross over into RI,, there are at least two trailer dealers
  7. #7
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,712
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    </font><font color="blue" class="small">( Big Tex trailers (pipe) type, aren't anywhere near as stout and the pipes get in the way.. )</font>
    What pipes you refering to? I have a big tex car hauler.. 7' clearance sidewall to sidewall.
    It's all 3" and 4" angle iron and box frame.. a couple big honking pieces of C channel...
    I've use dthe ramps off my trailer to help another guy load 10k# heavy equipment and not even had them flex..
    Soundguy
  8. #8
    Super Member George2615's Avatar
    Join Date
    Feb 2005
    Posts
    8,120
    Central Square, NY
    LS XR3037HC
    Jim,
    I also have the 2500HD w/ Duramax. I bought a 20' H&amp;H tilt bed trailer (attached pic, more in photo section). (H&amp;Htrailers.com) I don't know if you have a dealer in your area, I drove down to PA. to pick mine up. I only got the 7K rated one since it was all I needed. You can haul up to 12K bumper pull or 15.5K fifth wheel so what you get will depend on how much weight you want to haul. Price for mine was around $3400. It has brakes on both, removable fenders, &amp;7k drop leg jack, 14 stake pockets. I added the box with 8000lb. winch inside.
    George
    Attached Images Attached Images
  9. #9
    Veteran Member escavader's Avatar
    Join Date
    Mar 2005
    Posts
    2,288
    western maine
    bx-23 ,
    FARMER JIM,
    BIGTEX 14 ft tandem carhauler,for my little kubota[3000lbs],for my little jeep cherokee.Weight distribution hitch,electric brakes...nothin like it!!
    ALAN
  10. #10
    Silver Member RodgerF's Avatar
    Join Date
    Jul 2004
    Posts
    161
    S.W. PA
    New Holland TC 30, Kubota L3901DT, RK24 with FEL and mower, Massey Ferguson 35 and 2 Farmal Cubs
    I have an 18' trailer for my TC30. It has a 16' flat deck with a 2' beavertail. pic
    It works fine for my setup but if I were to do it again I'd probably go for a 20' trailer.
    Good luck with the trailer shopping.
    Rodger
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
