Neophyte
I'm thinking about purchasing a tilt trailer for my tractor and I have a few questions. Gooseneck is not an option in my case.
Question #1:
How do you determine the best length for your trailer? Do you simply measure the length of your tractor from the tip of the FEL bucket to the end of the longest implement? In my case, the longest implement would probably be the rotary cutter.
Question #2:
What makes for a better deck, wood or metal? What are the pros and cons of each? I'm leaning towards wood since it is less expensive, not as slippery when wet and can be replaced easily when it begins to fail.
Question #3:
Does anyone have input on these tilt trailers available on Ebay? I believe they are made or distributed by Sweet Rivers Farms.
eBay Motors: NEW 2006 18' Steel TILT DECK Trailer, Vettes, Mustangs (item 320026009428 end time Sep-15-06 20:25:23 PDT)
Car Trailer - Tilt Deck 1
They seem to use a manual hydraulic cylinder. I could probably live with this since I will be using the trailer pretty rarely. If I can't live with it, I imagine I could easily replace it with an electric or electric-over-hydraulic unit.
Question #4:
I believe they are selling a 16' Wood Deck Tilt Trailer for around $2200. Is this a good price for a tilt trailer?
Question #5:
I believe the trailer is rated at 7000 lbs GVW. Will this be enough for my JD 3320 with 300CX (73" Bucket) and implement? My tires are not loaded so I would guess the total weight for my setup should not exceed 5000 lbs.
Question #6:
Is there anything else I should be aware of when shopping for a trailer?
Question #1:
Question #2:
Question #3:
Question #4:
Question #5:
Question #6:
