Page 1 of 5 1234 ... LastLast
Results 1 to 10 of 41
  1. #1
    Join Date
    Aug 2006
    Posts
    115
    Eastern CT
    Kubota L3130 Cub Cadet 1554
    Default I need help chaining down the tractor
    Thanks for all the help on my previoues post(s). I haven't bought the trailer yet but I need advise on the proper, legal and safe way to chain my tractor
    (3130/LA723/BH90) to the trailer. Is it ok to run a chain around the brush guard at the front? At the rear the only place appears to be through the bottom of the backhoe? I think I need to separately chain the BH bucket? Does the front bucket need to be chained down also? Thanks for the help
    RPK
  2. #2
    Super Member George2615's Avatar
    Join Date
    Feb 2005
    Posts
    8,142
    Central Square, NY
    LS XR3037HC
    Default Re: I need help chaining down the tractor
    Generally, you should have one chain at each corner of the tractor. The BH and bucket also should have a chain. How the load is secured may depend on the weight of the tractor as well since DMV / DOT laws vary if the tractor is under or over 10K. I've seen many in my area only chain the tractor and not the BH or bucket. It's all a matter of whether you get caught or not.
    It is OK to run the chain around the brush guard as long as its attached to the tractor frame. I don't have a BH but have added two grab hooks to my 3 PT. arms for chains to attach to. Others have used a clevis to attach a chain to the drawbar.
    My opinion is the more chains securing the load the better off and safer for you and everyone else.
  3. #3
    Join Date
    Nov 2005
    Posts
    2,363
    Liberty, Kentucky
    None at this time.
    Secure your chains as if you are pulling your equipment apart. Picture your front chain point on the tractor as being the center of the hands on a clock. The chain should be pointing downwards to roughly 6 or 7 o'clock. The rear would be 4 or 5 o'clock.
    Next, you want the chains to angle outwards from the tractor towards the trailer sides.
    This satisfies the requirment against forward, backwards or lateral movement.
    Sometimes it is difficult to get the angle you want to achieve due to the tires being in the way. To the best of my knowledge, you can "crosstie" as needed. By that, I mean to run a chain from the left side towards the right side of your trailer.
    You can purchase leather sleeves to cover the chain to minimize paint damage when going over the axles for example. I would forgo the brush guard for the frame or axle.
    I would not worry to much about the front end loader bucket being chained but a backhoe bucket or any three point attachement should be. A single chain should suffice.
    Chain hooks should aways be inside of the rubrail if your trailer has them. Hooks should also go through the stake pockets if your trailer has them also. The chain may be fed through the center of a pocket or down either side but then come up through and hang on the pocket.
    That way, if the chain slacks, the hook will not fall away from the trailer.
    With "D" rings, I like to tension the chain with a bungees. That will keep the hook intact should the machine flex while moving.
  4. #4
    Super Member Bob_Skurka's Avatar
    Join Date
    Jul 2003
    Posts
    7,503
    I use grade 70 transport chain, 4 for the tractor, one on each corner. As previously stated, there is also supposed to be a chain for the bucket and another chain for the backhoe. I use ratchet binders instead of lever binders, I prefer them. I've heard that lever binders are no longer approved, but they still make them and sell them so they must be. I just don't like the fact that lever binders can pop open.
    AW Direct is one of the better sources for chain. I have the chain pictured below with the hook on one end and mult-hooks on the other end. It makes things very easy to tie down.
    Attached Images Attached Images
    Snow Trac, the Swedish Snow Tractor, at Wikipedia
    Never insult a man with a bag of dog poop in one hand and a tennis racket in the other hand!
  5. #5
    Elite Member wushaw's Avatar
    Join Date
    Mar 2005
    Posts
    3,075
    Bristol Texas
    Kubota L2800, 15 hp 372 Mitsubishi
    Bob; they make lever binders with a way to put a carobiner to saftey them from popping open, I have them and they seem to work just fine. Here is a picture of what they look like.TrucknTow - Dixiloc Locking Handle Load Binder
  6. #6
    Join Date
    Jul 2003
    Posts
    7,503
    Quote Originally Posted by wushaw
    That is a great design, it certainly stops the problem of them popping open. I know people who have the traditional style and use duct tape around them to keep them secure. The price at that website you linked is also a good one.
  7. #7
    Super Member
    Join Date
    Feb 2002
    Posts
    5,359
    western,pa.
    Kioti DK 35
    Quote Originally Posted by Bob_Skurka
    I pull all the slack in my chain to the center, then wrap the chain slack around the binded. Keeps them from popping.
    Vince,
    Kioti DK 35
    Hustler Super Z
  8. #8
    Silver Member jayhaitch's Avatar
    Join Date
    Jul 2004
    Posts
    246
    Manitoba Canada
    MF GC2310 TLB
    I've never owned/chained any vehicle before, so....
    I attach a clevis hook to grade 70 transport chain, and attach it to a loadbinder. The loadbinder is attached to more chain. This chain is wrapped around the tractor axle. Are those standard j-hooks meant to then attach back into the chain link itself, inserting the j-hook tip inside a link?
    I see the words grab hook, sling hook, and slip hook used. Are the grab hooks meant to attach back onto the chain itself?
    Ora et labora.
  9. #9
    Elite Member AlanB's Avatar
    Join Date
    Jan 2004
    Posts
    2,532
    Clarksville, TN, USA
    NH 1925
    The grab hooks have the narrower opening and are meant to latch into a chain.
    The slip hook looks like Captain Hooks, hook, and does not "lock" onto what it is hooked on.
    I do not know what a sling hook is, unless someone is referring to a slip hook with a safety catch on it?
  10. #10
    Join Date
    Jan 2002
    Posts
    1,501
    Lancaster PA
    Yanmar 186D
    I really prefer my ratchet binders but when I do use my lever binders, if I can't wrap the chain around them I wrap a bungie cord around. I watched a guy at the dealer tie a tractor down to a flat bed and he had some pieces of baleing wire that he twisted around the handle.
    Chris
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
