Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    May 2010
    Posts
    5
    Default 233 oil drain
    New to this site, I have a 233 bought this past winter. I need to do my first service. I have been trying to locate the engine oil drain. It appears to me there may two?
    I saw a lot of posts about service manuals. the links did not work. Any assistance locating one would be great. The owners manual is not that detailed.
    Love the tractor so fall. I am glad to see a site like this to see and share info on these tractors
  2. #2
    Gold Member
    Join Date
    Mar 2007
    Posts
    443
    NC
    Ford 5000, 3000
    Default Re: 233 oil drain
    If it is like the 273 there are two slumps with plugs. You may have to remove the brace from the bottom(under the slump) if the two holes do not line up.
  3. #3
    Member tym233me's Avatar
    Join Date
    Dec 2008
    Posts
    49
    Gray Maine
    TYM 233
    Budsoda is right on the drain plug just remove both after removing the brace
  4. #4
    New Member
    Join Date
    May 2010
    Posts
    5
    Great, thanks. I thought that is where they were. but wasn't sure.
  5. #5
    Silver Member honorbound's Avatar
    Join Date
    Apr 2010
    Posts
    122
    Orchard Park NY
    Kubota 3200HSD
    I have both service manuals on CD. One for the tractor and one for the engine. I asked the dealer for them and he was happy to burn them to CD for me.
  6. #6
    Gold Member Gregster613's Avatar
    Join Date
    Apr 2009
    Posts
    282
    Southern Ca. halfway up a mountain in rural Ramona.
    273 TYM. 2009 //Scotts L2048
    A note of caution however, there is a brass washer on each of those plugs and they tend to fall off the plugs very easily. You need be aware of this before hand, else you'll be fishing in the oil pan trying to locate them. I almost dumped them into my holding can while draining the oil sump catch pan. Good luck, have fun and enjoy your 233!
    Greg
  7. #7
    New Member
    Join Date
    May 2010
    Posts
    5
    Thanks for the advice on the washers. My luck I would have been fishing for them. I hope to get to it this weekend. Bought a fifth wheel and had to lower my truck to tow it, so I didn't get a chance to work on the tractor. I love it. It is really impressive what it can do.
Similar Threads
  1. Oil & Fuel 2554 oil drain leaking
    By diesel_nut in forum Cub Cadet Tractors
    Last Post: 06-26-2015, 09:35 AM
  2. Oil & Fuel Motor Oil as the Hydraulic Oil in Power Trac
    By DieselPower in forum Power Trac
    Last Post: 12-11-2014, 08:45 PM
  3. Help! Oil drain plug T273??
    By TYMinColton in forum TYM Owning/Operating
    Last Post: 07-01-2009, 08:31 AM
  4. Fragile oil drain on GT2542
    By vtcress in forum Cub Cadet L&G
    Last Post: 11-07-2006, 02:17 AM
  5. Oil & Fuel Oil Change Checklist
    By rdsaustintx in forum Kubota Owning/Operating
    Last Post: 10-21-2006, 01:59 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
