Page 1 of 2 12 LastLast
Results 1 to 10 of 19
  1. #1
    Join Date
    Jun 2006
    Posts
    135
    Missouri
    1532 hydro
    Default 233 questions
    looking at a 233 and was just curious for those that take the fel off. what do you do with the hyd lines that are hooked to the machine...Do you just tie them up? I see on the bota the quick disconect are mounted to the frame so no need to tie up the lines...also on a scale of 1-10 10=best how would you rate the tractor on reliabilty and performance..Thanks
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Silver Member honorbound's Avatar
    Join Date
    Apr 2010
    Posts
    122
    Orchard Park NY
    Kubota 3200HSD
    Default Re: 233 questions
    3 is my rating
  4. #3
    Gold Member myyaz33's Avatar
    Join Date
    Aug 2006
    Posts
    480
    Nebraska
    TYM T273
    Reliability = 8
    Performance = This really depends on the task..
    Ground engaging attachments like disk and box blade with rippers down. I'd give mine a low rating with the R4 tires on it. Just not enough traction even with loaded rears.
    Things like loader work and being able to get on soft lawns and rip out bushes without tearing the lawn up. I'd give it a 9. Backhoe is nice and has saved me a ton of shovel work.
    - TYM T273, BT200 Backhoe, LT200 Quick Attach FEL-
  5. #4
    New Member
    Join Date
    May 2010
    Posts
    5
    Id give mine an 8 as well. Agree with the tires. I wish the belly mower lifted higher. I have broken two rear casters and bent the front one. With the mower on stay on flat ground. but I can move 3 acres very quickly.
    I keep a short piece of rope tied to around the taillight then when I take the loader off I just tie the hoses around the post. could probably fab something to hold them but not a big deal.
  6. #5
    Join Date
    Apr 2010
    Posts
    122
    Orchard Park NY
    Kubota 3200HSD
    My rating was so low due to the fact that I have had numerous issues with the machine. The brake switch failed, the front boots failed on the tie rods, the HST spews hydraulic fluid when using the back-hoe attachment with no resolve yet. The machine is 9 months old. Other than that the fel has done all I asked of it. And the rear blade moved a lot of snow this winter.
  7. #6
    Join Date
    Jun 2006
    Posts
    135
    Missouri
    1532 hydro
    sorry to hear about your tractor problems,thats why I posted the thread to hear all the good bad and ugly...keep-em coming
  8. #7
    Join Date
    Sep 2005
    Posts
    1,576
    Batavia, NY
    Mahindra -------------
    Quote Originally Posted by honorbound View Post
    I am a Mahindra and TYM dealer in Batavia, and I don't like to hear that you are having trouble with your T233. Let me know if I can help you out with some of your problems. If the tie rod boot problem hasn't been resolved I believe I have some better quality boots that will fit them. Also let me know about the hydraulic fluid problem and I will try to get you some answers. I have a 293 out with a backhoe and there hasn't been any such problem with it, the customer says he is very happy with it. Let me know if I can help.
    Galen LaWall
    185 Pearl Street
    Batavia, New York 14020
    585.343.0770
  9. #8
    New Member
    Join Date
    Sep 2009
    Posts
    19
    Galin,
    It is nice to see an active dealer reading these posts. I have sent my dealer in RI and the national service manager (Ken) this link but I have not seen any response to user concerns. I suffer the hydraulic issue as well. It was erally bad initially but the hoses to the BH were reversed and the return line was on top and the volume caused the flow to leak out of the breather hole in the cap. I plugged it and the fluid came out of the breather tube. I took it in and had the the dealer look at it, they were perplexed. I recmmended switching the hoses based on a thread on this forumn. It helped but it still leaks from the hole. The resivoir/control has a bad design, as someone noted a baffle should have been integrated into the vessel. I hope they come up with a fix. The machine is a tough little machine and TYM can really grab some market share in this small tractor market but they need to address issues at a dealer as well as a dstributor level. maybe they will listen to you. Please keep in touch with the users, dealer comments give us hope.
  10. #9
    Join Date
    Sep 2005
    Posts
    1,576
    Batavia, NY
    Quote Originally Posted by km-ri View Post
    Galin,
    I was just wondering if you were to drill a hole in the fill cap and loop the vent hose into the fill cap, put a T into the top of the vent hose and run a hose from that. I wonder if the fluid would return to the tank and still vent air out of the T hose. I don't know if this would do the trick but it might. If it doesn't we have risked nothing but a fill cap.
    Galen LaWall
    185 Pearl Street
    585.343.0770
  11. #10
    Join Date
    Apr 2010
    Posts
    122
    Orchard Park NY
    Kubota 3200HSD
    My dealer has also been very helpful. Currently Ken from NC and my dealer in Orchard Park are looking at changing the control valve to the backhoe to a low return pressure one to see if this resolves the issue of hydraulic fluid spewing out. I have also let them know that the dif-lock is not working and that will have to be tested when they change the valve. I am not sure how a low pressure return will affect the backhoe but I am willing to give it a try. The boots, and the brake switch I replaced myself, after the dealer got them in for me. I dont feel that the dealer should have to deal with all the issues that this tractor has had. Of more concern is the fact that TYM Corporate in Korea wont deal with the issues. I am not about to give up and I want all issues delt with or a new tractor that doesnt have these issues. We pay a lot of money for these units and we should not have to deal with all these issues. Hydraulic fluid has ruined my garage floor, and I have tons of work that I cant get done until the tractor is fixed.
Similar Threads
  1. ford 1710 new owner with several questions
    By asylum in forum New Holland Owning/Operating
    Last Post: 05-21-2008, 11:48 AM
  2. Hydro leak- Questions
    By RadarTech in forum Kubota Owning/Operating
    Last Post: 03-10-2008, 10:34 PM
  3. Questions before my M6040 Purchase
    By air19 in forum Kubota Buying/Pricing
    Last Post: 09-01-2007, 09:54 PM
  4. Tractor Questions
    By SKOALMAN in forum Kioti Owning/Operating
    Last Post: 02-13-2003, 06:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
