Near Perfect Paint Match
   / Near Perfect Paint Match #1
Waterbug
Northern Michigan
TYM 293-HST
I was doing some Spring cleaning out in the barn today and came across a can of red spray paint, that was left over from a previous Honey-do. The cap color was pretty close to the color of my 293 HST, so I masked off a scratch on the tractor and gave the small spot a couple of coats. The color was nearly a perfect match. The paint is Rustoleum "Plastic". It is made to be used on plastics without using any primer. I believe that it only comes in one shade of red. It isn't a perfect match but well might have been, when the tractor was new ('09 model). If you're not looking for it, you can't notice the color variation. Definitely a good enough match for a working tractor.
   / Near Perfect Paint Match #2
waterbug throw a pic up so we all can see, thanks for the info. Your hood and fenders are plastic aren't they? (I thought they were when I was looking at them in '08)
I heard MF read from TSC is pretty close haven't got around to getting some and trying though.
I hope that this works. I took a picture and then drew a squiggly line around the area that I masked and painted. You're looking down on a section of the hood right where it curves from top to side.
   / Near Perfect Paint Match #4
WOW good job, looks great!
   / Near Perfect Paint Match #5
Thanks for the tip!
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
10 Ft Fork extensions (A50322)
10 Ft Fork...
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
1991 Gmc Top Kick Dump Truck (A50514)
1991 Gmc Top Kick...
2018 Toro Sand Pro Bunker Rake with Edger Broom (A49461)
2018 Toro Sand Pro...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
