Results 1 to 4 of 4
09-30-2012, 11:09 PM #1
50 Hour Service Question
I am about to perform the 50 hour service on my T293 and had a few questions because the owner's manual ... ummm ... sucks. First the manual shows a single engine oil drain plug but there are two bolt heads, one on each side of the drive shaft. From a separate thread here, I now know that these two are the drain plugs. OK. Easy enough.
Now the only remaining question is: Where is the strainer that the manual describes when talking about the Hydraulic/Trans fluid?
The manual states
1) to loosen the hose clamp and pull off the hose.
2) Remove the bolt
3) Pull out strainer
4) Clean and replace.
Which hose clamp? Where is this hose and bolt. All I see near the hydraulic fluid drain is a rubber hose with a 90 degree bend in it with 2 bolts attached to a plate connected to the hose.
Anyone have a T293 service manual in PDF form that they do not mind sharing?Tom
10-01-2012, 07:40 AM #2Silver Member
- Join Date
- Mar 2007
- Posts
- 184
- Location
- NC
- Tractor
- Ford 5000, 3000
Re: 50 Hour Service Question
It is at the end of the pipe. Rubber elbow, suction side where fluid comes out of the bottom of the reservoir. There are two bolts to remove. I don't think I changed my hydo fluid at only 50 hr, but if that's what your manual said then do it.
10-05-2012, 02:25 AM #3Platinum Member
- Join Date
- Sep 2002
- Posts
- 587
- Location
- East Lyme, CT
Your dealer can print you a shop manual but there may be a charge. Even if someone had the PDF it is way to large to email. Sorry.
This above all: to thine own self be true,
And it must follow, as the night the day,
Thou canst not be false to any man.
(Shakespeare, Hamlet)
10-25-2012, 05:06 PM #4Bronze Member
- Join Date
- Aug 2012
- Posts
- 74
- Location
- Greenback, TN
- Tractor
- T233
Use Pando - it's free and you can e-mail 1 gig at a time.
To date, I still do not have an owner's manual for my 233 or a service manual or ANY manual... except the wife.... she thinks she is my manual on everything cause she always seems to know what to do... so she keeps trying to convince me anyway.
Similar Threads
50 Hour Service
By jdun in forum Kioti Owning/OperatingReplies: 4Last Post: 07-13-2009, 11:00 PM -
50 hour service
By unclesalty in forum Bobcat TractorsReplies: 3Last Post: 06-25-2009, 07:30 PM -
For those who want to try 50 hour service...
By Typhoon in forum Kioti Owning/OperatingReplies: 1Last Post: 06-17-2009, 11:15 AM -
50 Hour Service
By pooters in forum Kioti Owning/OperatingReplies: 15Last Post: 06-16-2008, 01:28 AM -
50 hour service
By SCB in forum Kubota Owning/OperatingReplies: 17Last Post: 04-07-2004, 12:37 PM
