Results 21 to 25 of 25
02-28-2013, 03:49 PM #21New Member
- Join Date
- Feb 2010
- Posts
- 22
- Location
- South Carolina
- Tractor
- 2012 TYM T-233 with FEL
Re: T-233 Owner
Think it's 48", not home to measure it and can't remember off hand. It does a fairly good job for a medium duty boxblade. Wish it had a replaceable hardened scraper edge, I'll modify it to receive a bolt on edge when the time comes.
I agree with you on not getting a blade larger than 60".
Might want to barrow a 5ft boxblade from a friend / dealer and see if it works for your needs before buying one.
I have a 5' heavy duty Gill rollover box. I'm thinking of cutting down the length some on each end to lighten it up so the T-233 can pull it. It makes my 1950 Ferguson TO20 light on the frontend while in the raised position. It needs to be refurbished anyway, has some rust holes behind the bolt on scrape edge.
03-02-2013, 04:28 PM #22New Member
- Join Date
- Feb 2010
- Posts
- 22
- Location
- South Carolina
- Tractor
03-02-2013, 06:02 PM #23
03-03-2013, 12:50 PM #24New Member
- Join Date
- Feb 2010
- Posts
- 22
- Location
- South Carolina
- Tractor
Re: T-233 Owner
Thanks victormh!
Good job! You installed yours where I was planning to place mine. Any problems or interference on the inside of the dash support upright?
03-03-2013, 06:10 PM #25
Re: T-233 Owner
No, there is plenty of space to deal with the screws and nuts, I cut the extra lenght of the screws at the hood side so they don't come in contact with the dash support when you close it.
Similar Threads
233 questions
By drg1 in forum TYM Owning/OperatingReplies: 18Last Post: 12-02-2012, 06:44 PM -
233 problems need help
By honeydo in forum TYM Owning/OperatingReplies: 2Last Post: 10-08-2012, 06:50 AM -
233 driveshaft keeps disconnecting
By ac christopher in forum TYM Owning/OperatingReplies: 1Last Post: 11-01-2008, 02:14 PM -
new 233
By jaln in forum TYM Owning/OperatingReplies: 11Last Post: 10-07-2008, 10:09 AM -
New member here, owner of 233, quite the little machine
By Wobblin-Goblin in forum TYM Owning/OperatingReplies: 11Last Post: 04-01-2008, 06:20 PM
