brooksto
Member
- Joined
- Jun 11, 2012
- Messages
- 40
- Location
- troutville,va
- Tractor
- TYM 233, Kubota b2320, Simplicity Conquest, Cub Cadet slt1554, Ford lgt-12h
I have a t233 with the mid mount mower and mid pto. Today I bought a 5' bush hog and was going to test it out. Since the mid mount mower was still attached I was hoping to turn off the mid pto without having to unhook the mid pto shaft. (Didnt want to strain the tractor running both at same time) I then realized however that the pto lever to the left of the driver seat seems to be stuck. I checked the manual and it states the pto lever should have 3 positions: mid, mid+rear, and rear. The pto lever on my tractor is only labeled on/off, and there is some sort of plastic tab attached that would stop the lever half way back. I cant even seem to force the lever to this half way point, at least not where it will stay there.
Is there somthing I am missing? Should I be able to disable the mid pto like the manual states? Or are both mid and rear on all the time when the pto dash button is pressed and the lever is a dummy?
