Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    New Member
    Join Date
    Sep 2009
    Posts
    21
    Default 273 Drive shaft - Me too!
    All you 273 owners, check the drive shaft between the engine and HST. If you do not have universal joints I strongly recommend getting to your dealer and getting the the new design installed BEFORE the shaft lets go. Notice I said BEFORE. As mentioned in a previous thread the original design of this linkage was based upon three ball bearings used in a sleeve as contact points to transfer the torque of the engine into the HST. Holding the sleeve in place is a sheet metal collar. Not the most robust design. As you might guess mine failed a month ago and I just got my machine back (no fault to my dealer who was great). It took a little time to get the new parts. The new design has fully sealed universal joints. My mechanic says the tranny will go before these do (comforting). The first thing I noticed is the tell tale ringing/rattle I always heard was gone, not sure if they are related.
    My machine only had 300 hrs on it and I don't really abuse it. The toughest thing on the drive train is pushing snow with the bucket loader. Well thankfully TYM honored the warranty since I was only in my 4th year. The repair was done for the bubble, but had my hydraulic filter and fluid changed since the dealer had been so helpful. Hope you all can get this resolved before it bites you in the back side. Now if I could get the hydraulic fluid from leaking from the reservoir breather tube when using the backhoe I would be the happiest customer. Right now I catch the fluid in an old water bottle. It works but is a cheesy solution. My buddy who has a green machine gets a chuckle out of the arrangement.
  2. #2
    Platinum Member myyaz33's Avatar
    Join Date
    Aug 2006
    Posts
    733
    Nebraska
    TYM T273
    Default Re: 273 Drive shaft - Me too!
    You have a photo of your new drive shaft? Or the old one for that matter?
    - TYM T273, BT200 Backhoe, LT200 Quick Attach FEL-
  3. #3
    Join Date
    Aug 2006
    Posts
    733
    Nebraska
    TYM T273
    I assume the old one looks like this? Has anyone had theirs replaced before failure?
    Attached Thumbnails Attached Thumbnails 273 Drive shaft - Me too!-20130923_184800-jpg   273 Drive shaft - Me too!-20130923_184809-jpg
  4. #4
    Join Date
    Dec 2009
    Posts
    143
    bedford co. pa
    tym 233hst
    Quote Originally Posted by myyaz33 View Post
    I think u are showing the wrong shaft.
  5. #5
    Gold Member Gregster613's Avatar
    Join Date
    Apr 2009
    Posts
    283
    Southern Ca. halfway up a mountain in rural Ramona.
    273 TYM. 2009 //Scotts L2048
    Hi Km-ri, My 273 is a 2009 model and it has the universal joints. However, I always get that pinging/ringing noise about every 50 hours or so. What that tells me is that it's time for a shot or two of grease in the zerk fittings. Man, the one closest to the hydraulic filter is a bear to get at, but once it gets a touch of grease the noise goes away. It's been like that for 375.5 hours and is still going strong! Knock on wood! Ever since I read about the shaft failures I've been sure to grease those zerks whenever I hear the pinging/rattling. So, don't be surprised if you do hear the noise again, just crawl under and squirt in a shot or two of grease. Best of luck to you. Greg
    Gregster613
    (LT200 Loader, Woods RBC60 Angle Blade, Woods LRC60 Land Rake, Woods BB60 Rotary Mower, Woods PHD35 PH Digger, Woods GB48 Box Blade, Gearmore GR100 Middle Buster w/Potato Plow, Gearmore 3PH Forks, Gearmore Top & Tilt w/3 Spool Valve, Gearmore 48" Toothbar, Unkwn Brand 4' disk)
  6. #6
    Join Date
    Aug 2006
    Posts
    733
    Nebraska
    TYM T273
    Quote Originally Posted by ALKY View Post
    Certainly possible..
  7. #7
    Gold Member vabiker23518's Avatar
    Join Date
    Nov 2010
    Posts
    359
    Keysville, VA
    TM233
    273 Drive shaft - Me too!-universal-joint-jpg
    This is what half of mine looked like after it broke on my T233.
  8. #8
    Join Date
    Dec 2009
    Posts
    143
    bedford co. pa
    tym 233hst
    The attachment to the shaft is similar to an automotive steering shaft,but missing 1 important detail.A steering box shaft has a groove cut round the shaft for the bolt to seat in.Thus keeping the shaft in place. My 233 throws the shaft off all the time.A few times,I put it back on n sometimes it is junk.It sure makes u move fast when it flies off! lol
  9. #9
    Join Date
    Apr 2012
    Posts
    52
    Fingerlakes NY
    TYM 273
    Well the last two posts don't give me a lot of confidence in my recent repairs and new shaft. I knew that there was no groove in the shaft to help retain the shaft. My shaft has no grease fittings the universals are sealed.
  10. #10
    Join Date
    Aug 2006
    Posts
    733
    Nebraska
    TYM T273
    Did I post the correct picture? Anyone?
Similar Threads
  1. Replies: 5
    Last Post: 05-05-2013, 11:52 AM
  2. Replies: 32
    Last Post: 02-01-2013, 10:41 AM
  3. disc mower-- shaft drive or gear drive?
    By minerspic in forum Attachments
    Last Post: 01-29-2013, 08:46 PM
  4. DMM-60 Drive shaft to tranny input shaft roll pin (spring pin) gone
    By malk315 in forum Kioti Owning/Operating
    Last Post: 12-30-2012, 11:51 AM
  5. Belt drive or shaft drive transmission
    By lowerAla in forum General Lawn & Garden
    Last Post: 08-14-2006, 06:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
