Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Oct 2013
    Posts
    2
    Greenville PA
    TYM T430 with Backhoe
    Default New TYM T430 owner - few questions
    Purchased it for $11,500. Has front loader, backhoe, 1100 hours. Pretty nice shape, and I am happy with what I got for the price.
    I realize it won't come w/o minor issues...
    Few issues Ive run into:
    1.) Small sub-housing that the H/L/M/LL linkage connects into cracked. Its crappy pot metal. They are cheap to replace, but I am going to make one (have CNC) instead.
    2.) Chief bucket cylinders leak. Going to replace seals, hopefully its not a common issue... Are there better seals than OEM?
    3.) Snapped the swing chain on the backhoe today...It was a bit rusted, so I count that as a consumable. Will replace.
    4.) I took off the backhoe today to put on a tiller. It was a bitch to beat those pins out, but I got them. I might have to make some modified pins with zerk fittings, or at least strengthen up that small flat bar flange and weld some nuts to it for pusher bolts...would have saved a few hours of pissing around...
    One issue I ran into today - I hooked up the tiller, but for the life of me, I cannot get the PTO to engage in auto or manual. I tried different positions on the 3 point, different RPM's, tried starting the tractor clutch engaged, turn on PTO switch to manual and depress switch near steering wheel....nothing. PTO is in gear. I think that the electric clutch is not engaging.... Anyone have issue with this sticking? Is there a solenoid I need to look for to smack around a little?
    Overall I am happy with the unit, considering the price. a 43hp kubota would have been 10k more...for the light duty work I am doing, just wasn't worth the added expense.
    Attached Thumbnails Attached Thumbnails New TYM T430 owner - few questions-temporary_zps23794964.jpg
  2. #2
    New Member
    Join Date
    Oct 2013
    Posts
    2
    Greenville PA
    Default Re: New TYM T430 owner - few questions
    Figured out the PTO issue from another thread here. The PTO solenoid was sticking....a couple taps, good to go... I need to remove it this winter and get some lube in there. I am guessing the PTO didn't get used much on this machine b/c of the backhoe... But, regardless, got that working and did some tilling today - worked excellent. Amazing how light the rear end gets w/o the backhoe on it lol.
  3. #3
    Elite Member Redneck in training's Avatar
    Join Date
    Nov 2008
    Posts
    2,641
    South Central Iowa
    TYM 330 HST with FEL
    I think you did very good. Just the BH and the FEL would set you back close to 10K.
    Ladia
  4. #4
    New Member
    Join Date
    Sep 2012
    Posts
    21
    MA
    Ford 1700
    Default
    That looks like a Hardy 9DL on the back. I also have one. I really like the two foot extend a hoe on it.
  5. #5
    Join Date
    Oct 2002
    Posts
    676
    Pomfret,Connecticut
    yanmar 336d w ldr,C,Cub,many attachments
    great looking find there MBX- Enjoy !!
    From CT
Similar Threads
  1. New TYM 353 owner/operator
    By Rjoew in forum TYM Owning/Operating
    Last Post: 08-25-2011, 09:18 PM
  2. Michigan TYM owner
    By TYMlover in forum TYM Owning/Operating
    Last Post: 11-03-2010, 07:08 PM
  3. New TYM owner
    By Juve in forum TYM Owning/Operating
    Last Post: 07-27-2010, 05:54 PM
  4. new TYM owner
    By 273TYMinVA in forum TYM Buying/Pricing
    Last Post: 04-07-2010, 08:38 PM
  5. ITC Millennium Tractors? T430 Avenger
    By Anonymous Poster in forum All Other Brands
    Last Post: 08-16-2001, 11:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
