Results 1 to 4 of 4
  1. #1
    Default 3-point hitch stuck in up position on TYM273 HST
    Hi
    A few months ago I noticed the 3-point hitch was stuck in the upright position after I put the lever in the down position and turned the tractor off. I fiddled with the lever and it still stayed up. Left it for an hour and it settled to the down position. Now some months later it won't go in the down position at all, so the attachment (a box blade scraper) is stuck in the up position. The FEL is fine and so is the hydraulic fluid level.
    Any ideas?
    Thanks
    Chris
  2. #2
    Gold Member
    Join Date
    Mar 2007
    Posts
    269
    NC
    Ford 5000, 3000
    Default Re: 3-point hitch stuck in up position on TYM273 HST
    Check the lock adjustment knob under the front of the seat. Also make sure the leaver for the remote hydro's is in the center. If not that you have a problem with the valve body.
  3. #3
    Thanks Bud Soda. Was the knob under the seat. That's what comes of getting old and not using the tractor often. I forget these things.
  4. #4
    Member
    Join Date
    Jun 2012
    Posts
    29
    troutville,va
    TYM 233, Ford lgt-12h
    Default
    Dont feel bad thats happened to me several times, thought i had broken somthing and it was just the knob had gotten turned.
Similar Threads
  1. 3-Point Hitch CK30HST - 3 Point hitch stuck in up position - not the seat valve speed adjustment
    By ereilly in forum Kioti Owning/Operating
    Last Post: 06-17-2013, 07:59 PM
  2. 3 point hitch stuck in UP position
    By cherrypicker22 in forum Iseki
    Last Post: 10-06-2012, 09:39 AM
  3. 3-Point Hitch Cub Cadet 7195 - 3 point hitch stuck in up position
    By 5smokey in forum Cub Cadet Tractors
    Last Post: 05-01-2010, 10:02 PM
  4. 3-Point Hitch CK 25HST 3-Point Hitch Stuck in up position
    By jsharrard in forum Kioti Owning/Operating
    Last Post: 12-22-2005, 11:35 AM
  5. 3 point stuck in up position ???
    By kayssupply in forum Yanmar
    Last Post: 08-12-2005, 11:31 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
