Results 1 to 10 of 10
  1. #1
    Gold Member
    Join Date
    Mar 2007
    Posts
    284
    NC
    Ford 5000, 3000
    Default 273 died
    While using loader tractor shut down. No power to switch or anything. Didn't have a meter with me to check. Manual says three 50 amp fuses in wiring harness. I know one is near the battery. Anyone know where the other two are?
    Plan on going back to the farm with a meter Saturday to see if I can find the problem. Sure it has something to do with wiring rubbing the chassis while I was using the loader.
  2. #2
    Platinum Member myyaz33's Avatar
    Join Date
    Aug 2006
    Posts
    612
    Nebraska
    TYM T273
    Default Re: 273 died
    I think you hit the nail. Have you already addressed the wiring harness issue at the bottom of the firewall? Check there first if not. Mine fried there a couple years back.
    - TYM T273, BT200 Backhoe, LT200 Quick Attach FEL-
  3. #3
    Gold Member
    Join Date
    Mar 2007
    Posts
    284
    NC
    Ford 5000, 3000
    I thought I fixed the wiring problem a few years ago. At that time it was blowing a 7.5 amp fuse and the tractor would shut down but I still had power to the dash panel, switch, etc. This time all the fuses in the panel are good and there in no power to anything. Probably one of the big fuses in the wiring harness but I don't know where they are located.
  4. #4
    Join Date
    Dec 2014
    Posts
    541
    Armstrong, British Columbia
    1130 case,CK27 Kioti, 580 Super M backhoe
    Not familiar with your tractor but I had a fuse link go in one that did the same thing. Once I found it I replaced it with an inline fuse.
  5. #5
    Gold Member
    Join Date
    Mar 2007
    Posts
    284
    NC
    Ford 5000, 3000
    Turned out to be a 40A fuse taped to the wiring harness under the dash. None to be found so I took it apart, bridged it with solder and put it back in. Don't know why it blew but was probably wiring. I didn't find any bad spots but I pulled the wiring harness away from the firewall some.
  6. #6
    Join Date
    Jun 2014
    Posts
    178
    Keene, CA
    Kioti DS3510
    Quote Originally Posted by Bud Soda View Post
    Carry a fire extinguisher rated for electrical.....
  7. #7
    Silver Member Gregster613's Avatar
    Join Date
    Apr 2009
    Posts
    216
    Southern Ca. halfway up a mountain in rural Ramona.
    273 TYM. 2009 //Scotts L2048
    Hi Bud, Glad you found it, but what a pain it must be to remove the dash panel? I haven't yet had to dissemble mine - but suppose sooner or later I'll need to. Any tips on the procedure? Thanks, Greg
    Gregster613
    (LT200 Loader, Woods RBC60 Angle Blade, Woods LRC60 Land Rake, Woods BB60 Rotary Mower, Woods PHD35 PH Digger, Woods GB48 Box Blade, Gearmore GR100 Middle Buster w/Potato Plow, Gearmore 3PH Forks, Gearmore Top & Tilt w/3 Spool Valve, Gearmore 48" Toothbar, Unkwn Brand 4' disk)
  8. #8
    Gold Member
    Join Date
    Mar 2007
    Posts
    284
    NC
    Ford 5000, 3000
    Quote Originally Posted by Gregster613 View Post
    Not hard at all. Three screws, two bolts. Just needed to bring the bottom back enough to get to the wiring harness. The worse part was working on it in the 90f hot sun.
  9. #9
    Join Date
    Apr 2009
    Posts
    216
    Bud, To remove the entire dash assembly, don't you need to pull the steering wheel and then the ignition switch assembly also? And how are the gauges inserted in there? I get nervous when there are bunches of electrical items attached with the dis-assembly of a component. Probably shouldn't, but I just do! Thanks, Greg
    Gregster613
  10. #10
    Gold Member
    Join Date
    Mar 2007
    Posts
    284
    NC
    Ford 5000, 3000
    Didn't have to remove the top part of the dash where the gauges are, just the bottom part. If you ever have to get to those fuses or the relays for the cruse control or pto you can get to them through the bottom panel (left side) without removing the wheel and taking the top part of the dash off. May can get to the glow plug timer through the bottom also but I am not sure as I have not had to replace it yet. I do need to work on my tach and see what is causing it to read so high. I am sure the whole dash will have to come off for that.
Similar Threads
  1. 99 f350 fuel gauge died, 00 yukon fuel gauge died.
    By Soundguy in forum Parts/Repairs
    Last Post: 01-01-2013, 06:59 PM
  2. 273 died help needed
    By CDR in forum TYM Owning/Operating
    Last Post: 06-25-2012, 09:02 AM
  3. well, a 273 it is then...
    By myyaz33 in forum TYM Owning/Operating
    Last Post: 03-12-2008, 08:48 PM
  4. Price Check TYM Pricing on 273 and 273....
    By Hard in forum TYM Buying/Pricing
    Last Post: 06-27-2006, 08:01 PM
  5. YM 273
    By tmar04 in forum Yanmar
    Last Post: 04-11-2005, 05:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
