ok, so here's my initial impressions review. There’s a whole 5 hours on the machine now. /forums/images/graemlins/crazy.gif
I think the tractor is going to be just about the perfect size for my needs. It will zig zag around the flower beds and turn pretty tight. It is light enough that it doesn’t disturb the turf much, even after multiple passes through the same spot. My wife has already nicknamed it “LRM” (little red mule) because it has a lot more “umph” than it’s appearance suggests (or maybe because the stubborn guy who was operating it??).
So far, I have been moving piles or rocks/stone and cut up trees, pushing through briars and multiflora rose about 6’-8’ high and pushing over small trees that need thinned out. I haven’t run any PTO implements yet, but I would guess it to have plenty of power to run a 5’ brush hog. I’ve been pretty easy on the engine so far, not running it above 2000 RPM. I really haven’t had any reason to either. At that setting, I can hook the front bucket on a tree root, curl the bucket and lift the back wheels off the ground without the engine bogging at all. I knew I would most likely need a
ballast box on the back to get the most out of the loader, and will have my uncle weld one up for me. That’s ok though cause without it I can tool around the yard all day without tearing it up, and that was important for me. I’ve had no trouble, with just ballasted rear tires, going up and down the hill with a heaped bucket of mulch and stone without any trouble though.
Stuff I like:
A lot of engine for the size of the tractor.
The control layout is well thought out. I especially like the loader control and throttle location.
Two pedal hydro is easy to get used to and control. (this is the first hydro that I’ve run)
Not too big for around the bed paths, not too small for bigger jobs (with a little more weight hooked up.)
Style is pretty sharp looking. /forums/images/graemlins/grin.gif
While this unit was more than some others I looked at, the 5 year 0% financing made it about the same price as getting a lower priced model and using my banks interest rate for financing. I couldn’t do only 24 or 30 months at 0% either….Too big of a payment.
Stuff that could be better:
The seat belt isn’t very convenient to hook. It could use a 6” extension on the latch end. The belt end is fine.
Size 13 steel toe boots don’t fit between the brake pedals and the differential lock pedal without either being under the brake pedals or resting on the differential lock. If the brakes were a few inches forward that would be great. Size 13 sneakers fit in there fine. I’ve been told more than once that my feet are too big though.
The seat suspension could be better. It works fine, but the one on the Kioti is 10 times better. That seems like the last place to skimp. If I’m using the tractor, you can bet my can is in that seat, so it would be nice to have the best one. As long as I’m not driving fast on bumpy terrain, it does just fine though.
All in all, I'm really happy with it so far!
